Question about D-Link DSL 500 (DSL-500) Router
Convert Dear Sir, How can I setup the DSL-500T Router to be just a modem and itself connected to a PLANET router? Thank you. G.
Cant open this address
http://192.168.1.1
what about solution
Thank you
Posted on Apr 18, 2009
My Belkin wireless G router does not seem to work any more. If I connect my router to my DSL modem, I am not able to make a connection to the internet via the router to my iMac. However, if I connect the...
So if you connect the computer directly to the modem , it works .
That means your modem is working properly. Your ISP is DSL connection. Now connect the modem to the router and the computer to the router. Open the router xet up page and change the settings of the router according to the type of connection you have.
There are 2 types of connection in DSL.
DHCP and PPPOE .
Click Here for step by step instructions
Feb 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant get into 192.168.1.1 to fix problem
Do you have cable or DSL internet service? On a DSL setup the router is at 192.168.2.1 . At the run command, ipconfig/all will give all the current settings of your network connection. The line with default gateway is your router address.
Check the status lights on your router and modem as well as the network connection on your computer. You may want to try connecting to the modem itself with a wired connection and then reconnect the router and see if you can connect with a wired connection from the computer to the router.
If your network works normally with a wired connection, use the device manager to check your wireless connection. Also go through the router setup to check that no settings have been changed.
If you have missing lights on either the modem or the router, check the cables (replace them if you can) and transformers. A call for service from your ISP may be needed if the modem isn't connecting. (At least once, my DSL network went down after a lightning strike damaged the signal filter where the DSL split from the phone line.)
I hope this helps.
(I have an older router that does not give a local area connection if it loses the WAN from the modem.)
Nov 02, 2009 | Linksys Wireless-G WRT54G Router
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Setup router with vonage device and dsl modem
For the best call quality, I suggest you connect the Vonage router to the DSL modem, and if necessary, connect the Linksys router behind that. Why are you using a second router, though - you probably just need a switch or hub, if you're trying to connect more machines. Small networks rarely require more than one router. MaverickSolutions.biz may be able to provide additional support if you can give us more details about your installation.
Jul 20, 2009 | Computers & Internet
D-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
Apr 20, 2009 | D-Link DGL-4500 Wireless Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Inconsistencies in my D-Link DSL 500T Medem
I would most likely check the following:
Replace the ADSL filters and make sure there is a filter connected to every port in the house regardless of where the router is.
Also try a factory reset of your Dlink, reset the device and try again.
Sounds like a line fault though, Dialing 154 from a BT land line will get you through to the fault management service, they can generally help from there.
Mar 18, 2009 | D-Link DSL 500 (DSL-500) Router
Router problem
Hello!
Here is a guide on how to setting up port forward on DSL 500T for uTorrent:
http://www.portforward.com/english/routers/port_forwarding/Dlink/DSL-500T/Utorrent.htm
If you can't reach the router as described in the link above, than you need to contact whoever provided you with this router. If the router was provided by your ISP (internet service provider) than contact them directly asking how to access your router.
Hope this helps!
Sep 23, 2008 | Computers & Internet
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
D-Link DSL 500 (DSL-500) Router Logo
109 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
