Question about Magic Chef CMV1000B Microwave Oven
Microwave oven provides no heat
Tray spins & light works but no heat. In a senior moment, I used the microwave oven timer from 6 to 12 minutes. And similar to my head, there was nothing in the microwave.
Before I have a pro look at it, how likely is it that the magnatron (magnetron?) will have to be replaced. 90%? Any chance it's just a door switch or something else less expensive than a magnatron?
Thanks for any info.
  • 1 more comment
  • zmqr Sep 01, 2008
    That's right, I ran microwave empty for 6 to 12 minutes. I hope that many microwaves would have similar reactions to this abuse as I don't know model number. What do you think might be the result even if my microwave might be different?
  • mommyrox Sep 18, 2008
    I asked my 8 year old son to put pizza bites in the oven and set microwave timer for 8 mins and that I'd be right downstairs. It's the first time I've asked him to handle something like this. He did great except he forgot the part about using the microwave TIMER and he simply ran it empty for 8 mins. Now the thing won't heat! It's model number 721.80019401. Is a failed magnatron a simple fix or do I need a new microwave?
  • William Miller
    William Miller May 11, 2010
    Are you saying that instead of using the timer, you ran it empty for 6-12 minutes?
    What's your model number?
  • Magic Chef Master
  • 9,042 Answers
I would suspect that your (or any) microwave that is run empty and runs but does not heat probably has a failed magnetron.
With your model number (usually found on as together on the back, inside the cavity or around the door frame) we may be abel to point you to parts and repair sources.
Posted on Sep 02, 2008
Turntable does not spin, no heat
HV fuse has failed. Possibly caused by door switches or Diode Pack failure. Do not attempt a repair unless you are competent to do so. Extremely hazardous voltages inside!
Feb 27, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar GMV1540TB Microwave is not heating. Timer works but the tray is not rotating. If pushing the door up the oven can heat but easy to stop heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=-=-=--
Jul 14, 2010 | Goldstar MV-1526 Microwave Oven
The timer and lights work, but the carousel doesn't spin. It's not heating at all either.
heatman101'[-'[-
Apr 27, 2010 | Sharp R-1505 Microwave Oven
Will not heat
Is this a microwave you are talking about? If the clock and timer works, the light comes on and the tray revolves, but it doesn't cook food or heat stuff up, it is most likely the magnetron. Probably best to just buy another, as the cost of repairs not worth it.
Aug 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
Microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Jun 10, 2009 | Frigidaire FMV157GM Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat anything
take the cover off the machine and look for a 13amp fuse that supplys the tranformers. BEWARE!!!
when you open the machine disconnect from the mains and do not touch the high power circuits the capacitors can hold a charge that can kill.
Jul 06, 2008 | GE JES1142SF Microwave Oven
Microwave just quit working
Hi , Open the cover unsscrew it , be sure to unplug power ,if you have continuety tester , test the fuse if open replace it , is also availble in appliance parts center near you.
Feb 13, 2008 | Kenmore 62702 Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
88 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
sonic boom...
sonic boom...
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
