Question about Intel Motherboard
Help my computer is loding bios but it is stoping as it lodes wendos dut i have 1 other computer thats the same and can chang the hard drives around and it lodes up to wendows just fin on this computer but wen put in the other 1 it gos black but its ask to up date and did this than had this problom of not wonting to lode
Deseo obtener los driver originales de mi board
Posted on Sep 11, 2008
Windows wont start up on my labtop
May be your hard drive has crashed. How old is the machine?
Feb 17, 2017 | The Computers & Internet
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
I need to down lode my minicam pro but my disk wont work.is the a nothere way i can down lode it with out a disk
1st You download Webcam Driver.
I need to down lode
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 04, 2010 | GE MiniCam Pro HO98756 Webcam
Computer randomly shuts downs. i have checked ram/hd/psu and all are fine. It hasn't shut down on me in the bios or loding though or when playing games but it shuts down a lot when just in windows or...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 21, 2010 | Gigabyte GA-M57SLI-S4 (4719331821180)...
I was using apple laptop since 1 yr and every thing were open but suddenly since last 15 days orkut not being open on my laptop, it accept my username and pass but come a blank page and showing...
You should never format a hard drive without first figuring out if you can rescue it with recovery software. If it has a recovery program on disc or flash ..you will have to switch the bios to boot from one of the drives and reload with the recovery disc or flashdrive. It may also has a hidden partition which will allow you to run in safemode to fix the probelm.
Dec 12, 2017 | Apple Mac OS X Server for Mac
Laptop will not start past loading bar.
To check if the hard disk is faulty, check the BIOS setting to see if the hard disk is detected. The BIOS may have a hard disk diagnostic utility, if so run the diagnostic.
Another way to check the hard disk. Remove the hard disk and connect it to an USB hard drive adapter, then plug it into a working computer's USB port. The computer should detect it as an external hard drive and if you can see, open the folders and files then the hard drive is OK, if not then you need a new hard drive for your laptop.
Jun 24, 2009 | Gateway T-1631 Notebook
Cant load PIXMA MP140.it is trying to put it in my soft drive and not my hard drive
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 14, 2008 | Canon Office Equipment & Supplies
Wd500aaks driver
All you have to do insert any operating system bootable disk and then boot in CD/DVD rom and partition HDD and format and then install the operaitng system.
Here a guide on installing windows xp operating sytem :
http://www.geekgirls.com/windowsxp_install.htm
hope this help
Jan 08, 2008 | Western Digital Caviar SE16 (WD5000KS)...
Intel Motherboard Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
