"Write Protection" is a definate problem, but may be solvable (short of reformating) by checking the original files which, most likely, came from a CD copy. To see the attributes, right click on the icon and go down to select properties. There you will find "read only" highlighted for both the album folder and its sub files or songs. At this point the trick of avoiding "write protection" is to select the "read" attribute to unselect "read". Then select "Apply" and a window pops up showing boxes, one of which will say apply to folders, sub-folders or files, etc. Click on that box, then click on "OK". You will notice that the folder "read" attribute will remain highlighted, but that the subfolders' attributes do not!! (This is for Windows XP) At this point proceed to copy this folder OVER the same folder. You will be asked if you want to overwrite the existing folder with the same name. YES, please. The files will be replaced with identical file data, except the "read" attribute will be blank or unhighlighted, and NOW you can delete the folder.
SOURCE: My Sony Walkman NWZ-E344 won't connect to my
1st of all do you have the walkman programme installed on you laptop???
SOURCE: its a sony walkman NWZ-E344 mp3 when I try to
First unplug device from the computer. Go to Device Manager and look for NWz-E344. It may be under Portable Devices or under disk drives. It depends on your OS. When you find it, right click and select Uninstall. After it uninstalls, connect the player to the computer. The computer should run the plug-and-play add hardware to re-add the device.
SOURCE: Video Sync onto Sony NWZ-E344.
use a video converter to convert and make sure it's the supported size (320x480, i think) or downsize it.
SOURCE: Cant Put Videos in my sony walkman NWZ-E344!!
I don't have a solution either.
Nothing works. :( I tried YouTube free flv convertor on all formats but nuttin.
SOURCE: how do i delete music
Connect the USB cable on your computer - it should be read as a Mass Storage Device
Open the Disk and locate the songs you want to delete
Highlight and press DELETE on keyboard
