Unit made coffee, not espresso, replaced pump, descaled all plumbing, had power to pump after reconnecting electricals. Pump worked! Water at room temperature (obviously no steam). Circuit beaker tripped. Traced electricals doing continuity checks using DVOM. Found 2 thermostat connections reversed. LED portion of circuit now shows no continuity. Before ordering replacement, can the LED portion be tested using a simple continuity test? If the thermostats show continuity, are they proven to be functioning correctly? Is there something else I'm overlooking? Thank you in advance for your help. dougchesnut@yahoo.com
I will send you some documents, on the second page in the document you should check position 33, 34, 36 and 37 if 33 not work satisfactory then you not get any espresso.
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
my delonghi magnifica descaling button keeps flashing have followed instructions for descaling but...
(More)
my delonghi magnifica descaling button keeps flashing have followed instructions for descaling but cannot get button to opperate as the manual explains dont think it is descaling correctly any ideas ?
After repeated attempts I'm unable to prime my Starbucks Sirena Espresso Machine. I've followed the...
(More)
After repeated attempts I'm unable to prime my Starbucks Sirena Espresso Machine. I've followed the instructions in the manual to the letter with no avail. With water in the reservoir and the steam knob open at full no water is released via the steam wand. The magnet in the reservoir also moves freely. Any assistance would greatly be appreciated :)
