Question about HP Computers & Internet
HP Pavilion dv6000t will not reboot after installation of added memory. Produced a series of "beeps" one time only, but not again.
  • van12950 Aug 30, 2008
    The added memory (Crucial 1GB 200pin DDR2 SODIMM)was removed and reinstalled, but device will not boot! Could not complete thaurfen's solution since deveice will not boot! (Just 4 beeps) How can I get it to boot?
    Van
    Removed new memory...device still would not reboot.
    Brigadier General:
  • 6,966 Answers
If all else fails, pls try:
  • Clean the memory slots with a clean brush. It may help to use electronic contact cleaner (pls spray cautiously);
  • clean the memory pins with a pencil eraser;
  • verify that all other plug in components are seated correctly;
  • leave the laptop without the memory and the battery for some time.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 30, 2008
  • 300 Answers
Here is a link from Crucial that guarantees compatibility with your system.
http://www.crucial.com/store/listparts.aspx?model=Pavilion%20dv6000t%20Series
If the system doesn't boot, I suggest that you remove the new ram and temporarily reinstall the original memory. You will need to make sure that both retainer clips pop in place when you reinstall it You may also need to co into bios and reset system defaults to make sure that the memory is read correctly.
Hope this helps. Please remember to rate this information.
Thanks
    Brigadier General:
  • 5,158 Answers
Move both tabs away from the memory. carefully line it up in the slot and push down gently. if the memory is installed in the slots correctly both tabs will move up to hold the memory in place. reboot.... if that does not work install the memory in the other slot.
Robert
    Sergeant:
  • 241 Answers
How many slots are avaible
if you are adding to the board adtiontion memory you have to
make sure you are putting it in the correct slot. THE bios will tell you if it is installed
  • 2 more comments
  • Jayson Brollini
    Jayson Brollini Aug 30, 2008
    IF you are also running dual DDR ( two sticks) make sure of the config that *********** BOARD requires
  • Jayson Brollini
    WOW i guess mother board is a bad word
  • Jayson Brollini
    LOL sorry and the new stick is it the same as the other stick or is this a upgrade to a higher MB make sure that it too is the same as the original stick. You your BIOS just needs to read it. JKust go in there and see what it say/shows
  • Jayson Brollini
    IF you need addtional help post a comment
    Plz leave a rating for user
    Kindofcheap
    Master:
  • 638 Answers
Some thing is inserted not in correct position.
  • HP Master
  • 13,433 Answers
Hey,
Remove all memory from computer, start up, hear the beeps, insert one old memory. you should get picture. After this you can add another module.
What happens?
Thanks,
Ekse
  • Ekse Aug 30, 2008
    How many short / long beeps?
  • HP Master
  • 6,487 Answers
This can be a problem with the new memory, it may be not compatible with your MOBO or the memory is bad. So just remove the memory and try to reboot that should be working fine...
Hope that helps........
  • Mark Gil
    Mark Gil Aug 30, 2008
    Try to remove the old memory then just plug it back then try to restart the computer......
    Master:
  • 623 Answers
Click start
right click my computer
properties
hardware
device manager
?ports
scan for hardware changes
Hi, I have upgraded my HP Pavilion DV1000 RAM to 2G PC2700 DDR 333MHz, but after turning on it just makes 4 short beeps and screen is not turned on, please help me fix this error.
4 Short beeps would indicate during POST (Power on Self Test) there is a initialization issue with added hardware. The DIMM you added may not be compatible, or installed in the correct order.
1. Remove new memory completely, and see if machine starts
2. If you have original memory module still installed, remove it and try new one by itself.
3. If that works, put newer larger module in the 1st slot, and move original in second slot, and try again.
The system can automatically adjust memory settings (speed and timing) itself from the SPD module on every stick of RAM. However if the settings are drastically different, it can cause problems. Generally it will run as fast as the slowest module, but now always, sometimes causing the slower module to be attempted to run out of spec and cause boot issues or system instability.
Dec 06, 2013 | HP Pavilion dv1000 Notebook
Lights come on, fan comes on, no monitor, no HD activity, no bios beeps, all hardware removed from the under compartment. Still nothing.
Boot laptop with no memory installed should give seris of beeps to clear memory,next remove battery install mem if it boots ok battery hanging up laptop if not plug in mem one at a time to see if one is bad.
Jan 11, 2011 | HP 417035-001 - HP Pavilion dv2000 Series...
I down grade from vista to windows xp, after that my audio is not working. when i am trying to install audio drivers MSUAA and conexant driver then it showing failure message "could not find the MEDIA...
From HP's site:
Use the drivers from dv6000t cto series.Install Intel Chipset Installation Utility for ICH7(near bottom of list) first and reboot before installing other drivers.
For audio,install MS UAA,reboot,then Conexant drivers.All others can be in any order.You have Intel Pro Wireless and Network.
QP can't be reinstalled,at least not from HP.You can install the HP Quick Launch software and program your buttons to work with any media player installed.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3224055&lang=en
(Do Not use a bios from here)
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 20, 2010 | HP Pavilion dv6426us Notebook
Hp pavilion dv6000 turns onn and off
I had a similar problem with my pavilion. They have a cooling fan design that allows for lint buildup and subsequent overheating. You could try using a compressed air and blowing out the exhaust vent area for the fans.
May 27, 2010 | HP Pavilion dv6000t Notebook
My hp Pavilion dv6000 keeps restarting each time and the screen is left blank all the time. I don't hear any sounds either to detect any hw failure. It's reseting each 13-15 seconds after turning on so I'm...
dv6000, NO OS stated, whY? XP?
for now we get bios going first, damn the OS.
first take the old shorted main battery out,
run on AC only. run now? fan must blow first does it?
also the CCLF go dead, at 20k hours used. black screens for ever now. CCLF is dead LCD backlamps. but fan dead is other issue.
the COin cell goes bad now, ever replace that?
HP RTC coin cell battery , tiny, a $2 fix.
they dont last for 11 years, sorry.
power button dead?
fan dead,?
screen dead. (never ever shows text)???
hdd does not spin making normal noise?
cd eject button dead.?
no beeps?
no caps lock blink codes.?
the AC pack is dead if the PC is %100 dead on AC most times
I can show you 10 to 20 more things inside that can do that.
takes a full dismantle to fix some,
My guess a shop repair is not in the cards?
Jan 06, 2018 | HP Pavilion dv6000t Notebook
HP notepad - continueous beeping sound with equal sign characters
If you are getting a lot of = character along with the beeping, this indicates you have a stuck = key and the beeping sound is the keyboard buffer is swamped with the = character. If you can't unstick this key, then you need to replace the keyboard.
Jun 08, 2009 | HP Pavilion dv6000t Notebook
My HP Pavilion dv6000 keeps restarting with blank screen
I have the same problem with my hp pavilion! ive tried everything and cant get anything to appear on the screen. Keeps rebooting every 15 sec or so. Did you ever find a solution to this?
Mar 12, 2009 | HP Pavilion dv6000t Notebook
New memory installed in a HP Pavilion dv6000t Laptop-Booting Problems!
I have had bad memory straight out of the "box". Just becuase it's new memory does not mean it's good.
Take it back and get another stick.
Aug 30, 2008 | HP Pavilion dv6000z Notebook
Sound device problem
The problem is the software driver that will make your sound device is not installed.install the device driver.this wiil cure the problem.
May 19, 2008 | HP Pavilion dv6000t Notebook
HP Pavilion dv8000z
Sorry, it have the capacity of 1gb only.
Feb 22, 2008 | HP Pavilion dv8000z Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
