Question about Toshiba Satellite M40-S417TD Notebook
Wireless problem On my toshiba satellite m40 I must shut off the wireless adapter switch off and then to on to be able to get into the internet. If I do not do this I can not get into the internet even with switch in on position. It should automatically load the wireless so I can click in. I have made sure everything is enabled. Is there an area iImust adjust for this?
  • ldnleaf
    ldnleaf Aug 30, 2008
    I'm running xp home
  • ldnleaf
    ldnleaf Sep 01, 2008
    Turns out it need the bios and utilities updated
Use Function F8 key to make sure wifi is on
Posted on Dec 13, 2008
  • tonyliz Dec 13, 2008
    Just to clarify, press Fn key and then toggle F8 key until WiFi is selected on.
    Champion:
  • 200 Answers
If you are using windows vista
go to control panel
go to network and sharing center.
on the left side go to manage wireless networks.
remove all the wireless networks and restart the computer.
plenty of wireless network may affect and confuse the wireless adapter.
if still having the same issue then you will need to visit toshiba website and download the drivers.
cheers
Posted on Aug 30, 2008
  • peace maker
    peace maker Aug 31, 2008
    ok since u r running window xp then lets remove all the preffered networks and then try again maybe that will fix it
    click strat
    click control panel
    click network connection
    right click on wireless connection icon and select properties
    the second tab is wireless network click on that
    there is a box (preffered networks).
    remove all the networks from there.
    now connect to ur network and make sure when u select it to make it a preffered network and connect to it automatically.
    let me know what happened with u ok my friend
    cheers
Toshiba satellite 5005 s507 no wireless?
Use network to setup a wireless connection. You must have a RJ45 hard line for internet to perform this task.
Jan 20, 2013 | Toshiba Satellite 5005-S507 Laptop...
About toshiba m40 motherboard
Toshiba Satellite M40 Specifications (as reviewed):
Intel Pentium-M 760 (2.0Ghz, 533Mhz FSB)
1GB RAM (2x 512MB DDR400)
60GB (ATA 100 5400Rpm, 8mb Cache)
15.4" Widescreen TruBrite' Glossy display (1280x800 native)
NVIDIA GeForce Go 6600 128mb PCI-Express
Intel Pro 2195 a/b/g Wireless
Matshita DVD-RAM UJ-8315 (DVD-RAM, +R / + - RW)
Microsoft Windows XP Professional (SP2)
Toshiba 6.1 Hour Li-Ion Battery (6 cell; 4300mAh)
also see this... http://www.notebookreview.com/default.asp?newsID=2677
Nov 18, 2010 | Toshiba Computers & Internet
Wireless adapter crashes Toshiba Satellite A55
Try to update the wireless driver, also update the firmware (BIOS). it will fix your problem, it is software conflict.
Thanks
Oct 04, 2009 | Toshiba Satellite A55-S1063 Notebook
My wireless internet doesn't work, and the on/off switch is turned on
Hi,  Please do the following: Start>Run>type devmgmt.msc>under device manager>Right click on Wireless network adapter>uninstall, once done, click on scan for hardware changes on top. the network adapter would be back on its place. If that doesn't resolve the problem, reinstall the driver for wireless network adapter using the link given below: http://www.drivershq.com/Drivers/Toshiba/Satellite/L305-S5894/4183/9941/42341/Drivers.aspx
hope this resolves your issue.
your feedback is appreciated. Askari :)
Apr 22, 2009 | Toshiba Satellite L305-S5894 Notebook
After format, I couldn't connect wirelessly to the net, is it the card/adapter or the driver?
That would be the driver.  Make sure to re-install all of your drivers that have a yellow ? next to the name (right click on the my computer icon, and select properties. Find the tab that says "hardware" go to device manager and you will be in the right spot. )http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1042095&rpn=PSM40U&modelFilter=M40-S417TD&selCategory=3&selFamily=1073768663&selModel=1042095|PSM40U
Mar 17, 2009 | Toshiba Satellite M40-S417TD Notebook
Wireless network disconnecting
There should be a panel on the bottom of the laptop that you can access the wireless card from. I'd pull the card out and then reseat it back into the motherboard.
Should be pretty self-explanatory once you see it.
Let me know what happens.
Best of luck!
Feb 26, 2009 | Toshiba Satellite M40-S417TD Notebook
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite limitations on network adapters all wireless, need other
you need to log into the router setting by typing something like 192.168.*.* etc,check the right one for your router and enable some type of encryption like 128bits wep..Then your network is secured with a password which will stop anyone access.Now also change your router password if possible to prevent access from others...Hope this helps.
Sep 06, 2008 | Toshiba Satellite M40-S417TD Notebook
ATI Graphics driver for Toshiba Satellite laptop
Try this
http://cdgenp01.csd.toshiba.com/content/support/downloads/ta4videoax.exe
Jun 03, 2008 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite M40 Internal Wireless Card replacement
On the bottom of the laptop there will most likely be 2 panels to remove. One will be the hard drive, the other will be your RAM modules and most likely your wireless card. It'll probably be in the middle. Open this up, your wireless card will have two wires plugged into it that you'll have to unplug. Then on each side there is a tab that you have to click outward, then the card will flip up. Then you can just pull it outward. Do the reverse for installing the new card.
Aug 28, 2007 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite M40-S417TD Notebook Logo
144 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
