Question about HP Compaq Presario V2000 Notebook
I want to put a new fan - HP Compaq Presario V2000 Notebook
    Champion:
  • 200 Answers
Are we talking about CPU fan in a laptop????
if so please dont do it urself because that might not be thats easy
Posted on Aug 30, 2008
Fan works, put in new light switch, have power though switch and wire leading to sockets but when put in bulb power is not there any more.
If you switched to a different type of bulb with the new light kit, that could be the problem. Some remotes won't work with CFL bulbs.
Sep 19, 2015 | Hunter 52" Ceiling Fan With Light And...
How do i check the fan relays and the fans to see if they work
unplug the coolant sensor and the fan should come on when u unplug it
the ecm grounds the fan relay so the relay gets power all the the time
13 year old malibu most likely the fan motor is bad put direct power to it.
Feb 24, 2012 | 1999 Chevrolet Malibu
My 99 ford expedition is overheating. We've put on a new water pump, new serpentine belt, new thermostat. What else is there that could be causing this problem.
check the cooling fan if it's just clutch fan the clutch is probably bad if it's an electric fan check and make sure the fan is comming on
Apr 14, 2011 | Ford Expedition Cars & Trucks
Radiator fans not working
Check your connections on the fan. There are electrical plugs on the fans that connect to your cars electrical system. Check this, especially if you just put in a new radiator.
Mar 23, 2009 | 1992 Dodge Dynasty
Fan won't shut off w/remote.
Does the remote have a dedicated button for off/on lights, and then off/on fan?
I assume it used to work,,???
First, regardless, replace the batteries in the remote, even if they are new.
This will do two things, reset the remote and double check the remote is powerful enough to send a strong signal.
Do you have the original set up manual for the fan?
If this is not a new install, and it simply quit, get out the manual and perform the original setup.
Sometimes there are "modes" setup on the fan by how long the wall power switch is on or off, say on for 30 seconds puts it in test mode, or on/off in less than 30 seconds puts it in operational mode.
Not knowing what you have, I cannot say that you need either a new fan or new remote, I need more information about the entire situation.
write me at service @emrrepair.com
Will
Nov 29, 2008 | Hunter 52" Ceiling Fan With Light And...
Loud Cooling Fan
that fan is very loud on that truck. if its not makin noise its not cooling. common on gm trucks
Sep 29, 2008 | 2001 GMC Sierra Crew Cab
Can i put fan on pny verto geforce 6200
Yes you can and this will propably solve your issue. You can put any 5v or 12v fan that you can fit on the vga heat-sink. Do not attempt to power the fan directly from the vga fan connector. Use a normal fan that will connect on your PSU outlets. Try not to damage the VGA while doing so.
Feb 11, 2008 | Computers & Internet
KIRBY G4 FAN ASSEMBLY ORDER
First put the gasket on the spacer, thin end to to out, push it down all the way on the motor shaft, then put the nylon washer on, then the fan, metal washer and then the pulley, just snug it, (don't tighten too much just beyond hand tightening). Put the casing, top and handle back on.
Feb 01, 2008 | Vacuums
HP Compaq Presario V2000 Notebook Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
