Question about 3Com (3C16593BN) 24-Port Ethernet Hub
Hub not working properly
The hub is not working properly unless I connect a certain cable
Maybe your hub port is not using auto sense port.
Posted on Oct 04, 2008
    Problem Solver:
  • 35 Answers
Maybe you hub port is not auto sense.
My VGA cable won't let the image on the screen stay on unless I hold it a certain way
Either the ribbon cable is faulty or it is not making proper connection to the motherboard.
Try reseating the video cable to the motherboard before you try getting a replacement cable.
Apr 12, 2012 | Acer Computers & Internet
Reconecting the cables to the hub does not make a network
Not necessarily! As long as a lan cable is connected on the wan port of your hub and the other end goes directly to the modem, the connection is correct. The remaining port will be left for the lan cables of the computers. No orders needed. Just make sure that lan cables was properly seated on the port. The LED blinking in the hub will tell you if its working or communicating with your computer. Find it, when the LED is not lit or blinking, the lan cable is not connected properly on the hub (or the other end of the lan cable is disconnected from the lan card of the computers).
If all cables are connected properly and still cannot connect to the network, you may need to refresh the name of the workgroup on the computers that cannot connect on the network,
How? Right click on My Computer.
Select Computer Name
Click Change to change the name of the workgroup that is being use by other computer. Delete the old name if the same and retype.
Restart the computer and try to connect using network neighborhood.
Jul 07, 2010 | D-Link DSH 16 (DSH-16) Networking Hub
XP computer - USB slots do not work for all storage devices I plug in. Ok for example, with usb key, but will not work with external disk which I use for backup. It did work before. The usb slots at the...
There is a problem with the usb outlet not with OS. try to check if the connection from the motherboard is connected properly and if does, then there is a really problem of the usb outlet.
Oct 23, 2009 | Computers & Internet
4 port HUB is connected. My computer doesn't show it. Help! It is all plugged in with USB cable and when I go to MY COMPUTER it doesn't show.
The hubs usually show up in the hardware list and not as a seperate device. Only way to know it is there is to plug a usb device into it.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Sep 05, 2009 | CyberPower CPH420P 4-Port USB Hub
Usb ports not working
Check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Also check HP's support section on the web for any updated drivers especially for your laptops motherboard / bios
Once you have done that try some of the common fixes below.
Aug 30, 2009 | HP GbE2c Layer2/3 Ethernet Blade Switch...
Hiya, i have a Freeagent 250gb external harddrive that was working fine one minute but now will not connect to my computer and keeps stating that the devise is not recegnised and inturn doesnt work? any...
Hi Chris
Quick checks of the drive itself can be done by removing it from its enclosure and connecting it directly to a comuter that has the correct interface. If you can read and use the drive then you know it is not that.
If you cannot use the drive in any way and esp. if you hear clicking or pinging then the drive is almost certainly dead or dying.
Aug 25, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Sky tv(free) thru BT home hub wat cables do you need
There are some sat that r working with what is called slingers or iks and hub but to get those channels you still have to pay for the iks and slingers. I would check the sat forums.
Jun 13, 2009 | Computers & Internet
I have a lexmark x5470 which i have installed onto my wireless laptop. It works fine when plugged in with the usb cable but i can't get it to work wirelessly!
hmm..ok...then you are most likely experiencing the old IP shuffle..
usually, when a printer is on a wireless hub, unless it's connected directly into that hub, there is always the IP assignment issue.
check your wireless hub's specs
Aug 19, 2008 | Lexmark Office Equipment & Supplies
Wireless key on my laptop it wnt work
Check all cable connections
Ensure devices are powered on
Check the cable connection or to the hub ensure you have green link light
Make sure you are using the proper cables - CAT5e ? CAT6 - not crossover
Jun 09, 2008 | Computers & Internet
Pc's say a network cable is unplugged
First, NO, crossover cables are for connecting LIKE devices.. you need a Straight Thru cable for connecting 2 PCs to a switch.. So, if you are using Crossovers, then you are getting the correct results (cable unplugged). Replace with the proper cables, and it should see the network fine..
Also,
As this ProCurve HP 408 is 10/100 auto sensing, you should be able to automate speed and duplex within your NICs conifiguration...
Happy Holdiays!
Dec 22, 2007 | HP ProCurve 408 Networking Switch
3Com (3C16593BN) 24-Port Ethernet Hub Logo
430 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
