Downloaded FaxTools eXPert and then received the CD. Paid by CC order #1019651306...CD says the reg# is wrong.. I have never been able to send a FAX using this software. Tell me how to fis or credit my CC.. I am not computer smart but, I ought to be able to figue this out. It keeps saying I have a SMPT Problem. Please Advise...Robert Harp bobharp@bellsouth.net
    Scholar:
  • 113 Answers
I sugest you go to this webpage, then look at the single review which has been posted.
http://www.topshareware.com/FaxTools-eXPert-download-14292.htm
If you can send (SMTP) and receive email (POP3) then there can't be anything wrong with your settings!
Sorry I can't resolve this issue for you, but at least you know your not on your own
Posted on Aug 30, 2008
    Genius:
  • 2,035 Answers
Do you any antivirus or firewall please give exceptions and then install the software and try to fax ,if you still encounter same problem then you can contact the company support LINK:
http://www.avanquest.com/USA/corporate/contact/index.html
Good luck..
    Genius:
  • 3,422 Answers
IF the registration no. given to you is wrong then the only way to get that is to call the customer support of faxtools and get another one.Just tell them your order no.
  • Priya darshan Aug 30, 2008
    Please don't forget to accept the solution
    Master:
  • 623 Answers
It's better if you contact the site you downloaded cd from..
thank you and good luck
  • 6,487 Answers
Since the reg# number is not working it will be better for you to return that where you purchased it , because you paid for it that's should be working fine..
Good luck.........
    Sergeant:
    Champion:
  • 236 Answers
Unistall the software and re install using the CD.
this should clear the trial dowloaded.
    Master:
  • 638 Answers
Its not the proper full version you received.
  • 2 more comments
  • hemant somaiya
    hemant somaiya Aug 30, 2008
    10 Responses for "SMPT problem!"
    1. Pepper_1 November 20th, 2006 at 2:21 pm 1
      Hi
      Normally, we can’t send email through the SMTP server of one ISP while currently connected to a different ISP. To resolve this, simply send ur email using the SMTP settings of the currently-being used ISP, and just set the reply/return address to your original email address.
      For example:
      Your corporate email is hosted by, say, ispOne.com
      If you send email, you use smtp.ispone.com (assumption lang ng smtp server)
      But if your current connection to the internet is SmartBro.
      Your smtp settings should be smtp.smartbro.net for it to pass through, else you may get a relay error.
      If you’re using Outlook Express, create two email accounts - one for ispOne and another for SmartBro. You can still receive msgs sent to your ispOne inbox and able to send outgoing email.
      ‘hope this helps….
    2. mylane February 6th, 2007 at 8:31 am 2
      I actually setup my SMTP (I’m using ThunderBird) to smtp.smartbro.net but it still not working. I keep getting an error.
      But when I tried to send mails in my smartbro account (provided by them) the email was sucessfully sent. Seems I cannot send emails from other domain than smart bro.
      Please advise.
    3. hurricane24 February 12th, 2007 at 3:44 pm 3
      yeah that’s absolutely right. i tried sending a couple of mails to a “@yahoo.com” domain but i just failed. on the first few days after i setup my ms outlook it was working fine. there seem to be a problem on their server not ours.
      btw, i use this setup on ms outlook. never tried thunderbird though.
      incoming mail: pop.smartwifi.com.ph
      outgoing mail: smtp.smartbro.net
      try setting up other email clients like ms outlook and test it there or disable any firewall if you have one.
  • hemant somaiya
    1. April 24th, 2007 at 3:48 pm 4
    2. here’s how I fixed it. Leave your POP3 setting as is. Change your SMTP to smtp.smartbro.net
    3. Now the bit it doesn’t tell you anywhere on the internet….
    4. In “More settings…”/Outgoing Server check the MY outgoing server (SMTP) requires authentication. Check the button for Log on Using and input your username and password given to you by Smart. Click OK , next, finish. Go back and try to send test email
    5. No username or password coz Smart forgot to tell you???? Username is the first letter of you first and second name plus your family name. eg Charles B Atlas -> cbatlas and the password is 123456
    6. Switch OFF any STMP accelerators such as OnSpeed if you have them installed.
    7. Cheers
    8. JJ95
      http://www.mdmc.org
    9. big hentai manga o April 30th, 2007 at 10:07 pm 5
      big hentai manga o
      big hentai manga o friends
    1. spread ***** tgp April 30th, 2007 at 10:51 pm 6
    2. spread ***** tgp
    3. Info about spread ***** tgp.
  • hemant somaiya
    1. January 29th, 2008 at 9:43 pm 7
    2. I’m having the same exact problem - could not send email when using outlook 2007 but i could receive one.
    3. I’ve already these settings:
    4. incoming mail: pop.smartwifi.com.ph
    5. and
    6. incoming mail: pop.smartbro.net
    7. ** ANd either way, i couldnt receive any email still. **
    8. ~SET-UP INFO~
    9. Internet Email settings:
    10. (General)
      [myusername]@smartbro.net;
    11. (outgoing server)
      checkbox for outgoing server SMTP requires authentication is checked w/ my logon info.
    12. (connection and advanced menu)
      I used the defaults.
    13. I hate to call smart TS because it’s BS to wait for so long on the line and be placed on a loooooooooooong hold for no resolution.
    14. WHen doin the repair/diags, POP3 appears to be good but the prob here is with the smtp which appears to be a problem with the server itself - and our ISP should take care of this concern. I’ve already emailed them and never got a response. That’s pretty odd..
    15. jay
  • hemant somaiya
    1. January 30th, 2008 at 2:50 pm 8
    2. im using mac mail and smartbro. i had my yahoo account set up in my Mail app using smtp.mail.yahoo.com.ph and i can send and receive emails.
    3. iMark Designs March 18th, 2008 at 7:57 pm 9
      one more thing.. i can’t send emails using other domain, specially my own personal domain email address.. bull-**** to all developer/engineer of technical broadband that can’t solve this kind of **** puzzle. IMOE i have tried to send many times in Smart ***, but no luck. and when i use Globe ****, it can send many as you can. so, is this the time that do we need to jump ship to the other ?
    1. Jo June 6th, 2008 at 12:37 am 10
    2. Im using my personal webmail in Outlook
    3. On the advanced settings..
    4. Enable SSL on both pop and smtp..
    5. and use the following ports:
    6. Pop: 995
      SMTP: 465
    7. Hope this helps..
    Sending a fax
    You are doing it in the wrong order.
    Press FAX. Load your document/s. Dial the number and press black start. It will take up to ten pages automatically That's it.
    Jan 29, 2014 | Sharp MX-2600/MX-3100N Black Toner...
    Help kobobooks com
    We can't do anything about this. With Kobo, books are paid for as they are downloaded, not pre ordered.
    Aug 26, 2017 | Computers & Internet
    I am unable to send a fax or receive, how do i correct problem
    Uninstall HP Photosmart software and Drivers for printers. Remove all the HP softwares. If you have CD reinstall printer and HP Photosmart software from the CD.
    Other wise download the complete software and drivers from following link.
    http://h10025.www1.hp.com/ewfrf/wc/product?product=1119598&lc=en&cc=us&dlc=en&lang=en&cc=us
    Jul 06, 2011 | HP Officejet 6310 All-In-One InkJet...
    How do i set up the fax to print a confirmation sheet when it sends something?
    Try this:
    Press the Setup button (it might be the sign of a monkey range)
    1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
    2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
    3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
    On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
    Select the one you would like to choose ;
    For further help click on the following Link:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01083680&cc=us&lc=en&dlc=en&product=3204785
    Regards Soumajit
    Sep 21, 2009 | HP Photosmart C7280 Laser Printer
    How do I get a fax conformation?
    This is an excerpt of the User's Guide for your machine. You can download from here:
    http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
    Print fax confirmation reports
    If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
    The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
    each transaction.
    To enable fax confirmation from the control panel
    1. Press Setup.
    2. Press 2, and then press 1.
    This selects Print Report and then selects Fax Confirmation.
    3. Press to select one of the following, and then press OK.
    Send & Receive Prints a fax confirmation report for every fax you send and receive.
    User Guide 65
    Fax
    Tip
    If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
    Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
    Did not receive merchandise ordered july25,2009 ordere #0596-4307-9495-1243 it was paid already by my credit card the merchandise was St. philomena 2 cd set
    When that happen you need to contact you cc and tell them about the problem you must report it to the FROUD department. The sooner the better.
    Was this helpful?
    your rating and comment is very important to me. thank you
    Aug 07, 2009 | PayPal Computers & Internet
    Received faxes on brother fax 1360 incorrect order
    you cannot control PAGINATION, have the sender reverse the order of sending.
    Nov 14, 2008 | Brother Fax-1360 Plain Paper Inkjet Fax
    Cannot Send or Receive Faxes
    here you might find an answer:
    http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
    Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
    Lexmark X6170 fax bvrp
    it's supposedly bundled with that printer..
    here are some instructions..
    How to Install BVRP FaxTools Software on the Lexmark X6130/X6150/X6160/X6170/X6190 Pro ID:ENUS8694 null.gif null.gif null.gif
    The FaxTools software is on the Lexmark X6100 Series Installation CD. During installation of the printer driver, you will be asked whether you want to install it. If you choose to cancel this option during the installation process, you can install the software separately as follows:
    1. Insert the Lexmark X6100 Installation CD into the CD-ROM drive.
    2. When the Install Software screen appears, click Cancel.
    3. Right click on the Start button and select Explore.
    4. Click on the plus sign (+) beside My Computer .
    5. Click on the plus sign (+) beside the Lex X6100 CD.
    6. Double-click on the FAX folder.
    7. Double-click on the relevant language folder on the right-hand side.
    8. Double-click on the Setup executable. (Note: The correct setup icon is the one with two white arrows on a grey foreground.)
    9. Follow the on-screen instructions to complete the installation.
    Feb 18, 2008 | Lexmark X6170 All-In-One InkJet Printer
    Computers & Internet Logo
    48 people viewed this question
    David Payne
    David Payne
