Question about Miller Electric Mfg Co 903505 Invision 456P MIG Welder , 3- Phase, 10 - 38 V Type: 230/460 60HZ
Mastercraft arc welder
Wire is coming out to fast switch stuck on maximum speed how can i turn it down
  • Anonymous Mar 28, 2009
    I have a mastercraft wire feed welder 70A. The wirefeed does not turn when the handle trigger is depressed. The welder makes a buzzing sound but no wire movement. Any soluntions?
I have a mastercraft welder wire feed , the power turns on the wire feed works and the fan in side turns on but it will not weld not even a spark! can anyone help?
Posted on Aug 17, 2011
    President:
  • 1,263 Answers
Your going have to replace the switch you usually can replace it with an after market one
Posted on Sep 01, 2008
Terrencio nailed it, it's actually the drive mechanism itself. no bearings and everything except for the drive wheels and the tensioning bolt
Posted on Sep 09, 2010
  • 20 Answers
I just bought one today, 1/2 price. might as well been free for all the use I got out of it. The wire stopped feeding properly after 2 minutes of use. I took it apart only to find the shaft for the feeder wheel is supported by plastic !! it has no support bearing, and the feeder wheel is binding on the plastic shroud. With the tension adjuster removed it works fine, but apply pressure and it binds. There is an incredible amount of up and down as well as end play in the shaft. What a P.O.S. !!! Crappy Trash just earned their name. My advice, take it back and get a refund, no store credit B.S. just return it and buy a miller....The real kicker is they give you extra nuts and bolts for the cart, yet can't figure out that a friggen sleeve bearing would've made the damn thing actually useable...
Posted on Sep 25, 2009
  • 92 Answers
The wire feed is controlled by a dial not a switch, check you are using the right component. the dial will have "WFU of WF" printed under the dial, turn this anticlockwise and with the tentioners disengaged, notice the rollers going slow or fast as you turn the dial.
Posted on Jan 24, 2009
I have a mastercraft arc welder that turns on but won't arc the overload light is not on or enything
I'm not familiar with this model and I don't know it's age, but as a general check item on any welder, make sure your welding leads are in good shape and that your earth clamp is actually connecting to it's lead. They can burn and tarnish with use and fail to connect. Check likewise the lead connection into the electrode holder. Check their attachment to the welder unit too. There may be a thermal overload protection fuse/device/switch inside the unit which may need to be reset/replaced if you've worked it heavily recently.
If the welder is TOTALLY silent when you switch it on, it may indicate a transformer failure for some reason, usually there is a little bit of buzz or hum. Within safe limits (bear in mind there are dangerous high voltages inside the welder) you might use a simple multi-meter to check that you are getting transmission of power from A to B throughout the unit to the work piece, and that you've got adequate voltage arriving at the work. More safely, with input power totally switched off and unplugged, you can use a multi-meter to check continuity of circuits through the welder to make sure there isn't a break in connection somewhere from a component fault or failure.
Nov 15, 2014 | Garden
My mastercraft ark welder turns on but won't ark the overload switch is not on
Get someone with electrical knowledge to test the circuits. Do you mean an Arc Welder or do you mean a MIG Welder? They are completely different in operation.
Kende weld no arc
make sure your work-piece has a proper ground. and maybe check your gas connection. no leaks. maybe turn gas down.
Mar 27, 2013 | Welding Tools
Weld arc not stable. Wire feeds, good ground, everything looks good, liner pulled and cleaned, new tip.
Try moving the tip closer to your work and try turning your wire speed down
Most people want to crank up the wire speed when it spits and sputters
Turn it down
See if this helps
Mar 16, 2010 | Hobart Handler 140 Mig Welder
Hobart 210 makes an arc but the wire feed motor won't turn. used very little ,has voltage at motor,worked fine the last time i used it
hi,
maybe you haven't got the wire speed control turned up probly not the answer but sometimes its the simply things.
Mar 02, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Trying to weld with Hobart 125 EZ
If you are using flux wire and not shielding gas, your clamp should be positive and the wire should be negative. Heat is provided by the electrical arc that happens between the wire and the material. Your welder by itself does not pre heat the material and with 3/16 material you should not need to preheat anyway.
The electrical arc is kept consistent by adjusting the wire feed rate and the current applied. You will need to experiment with these settings to find what works best with your welder. For this welder and 3/16 material, I would suggest you start at the upper end of the current scale and about a third of the way up on wire speed. The welder might have a chart for these settings in the manual or inside cover.
If the wire feeds too fast, it will push the probe around and you will feel pressure as the wire feeds out. If the speed is too slow you will get large spatters and intermittent arcs. When properly adjusted the arc will sound even and consistent. The arc gap should always be about 1/8 of an inch.
To maintain enough heat for good penatration, do not move the probe too fast, work in a pattern and watch the weld pool (melted metal) and not the arc. Watching the weld pool will clue you in if you are moving too fast or too slow.
I hope this helps.
-Scott
Feb 03, 2009 | Hobart Handler 125 Ez
Flux wire welder will spark but will not weld continuously
Clean the plate/sheet firtst then attach the earth ensure you have fitted the same size tip as the wire, check all the switches on the set that the are pointing for the conditions, If it is arc as well as TIG. there will be a little switch that you move for either TIG or stick welding .( could also give "LIFT TIG")
Jan 15, 2009 | Miller Welding Tools
Miller Electric Mfg Co 903505 Invision 456P MIG Welder , 3- Phase, 10 - 38 V Type: 230/460 60HZ Logo
1,137 people viewed this question
Top Miller Welding Tools Experts
John Trevino
wadingriver
wadingriver
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
