Trying to use wireless and says aquring network address but doesnt go any farther
I clicked on repair under my wireless connection and it fixed it for me
Posted on Aug 30, 2008
Emachine won't connect to the internet. Ethernet cable, router and modem all work just fine. problem is with computer. Check network adapters in device manager and no problem noted there. Why won't it...
first try to check if your wireless can actually detect a network, if it can try to remove ALLthe network that you have on your wireless network and try to add your network again, if still doest work try to uninstall and re install your wireless driver, if it still doesnt work try to restart your router, if still doesnt work try to do system restore to the point where your wireless was workin fine, lastly if still doesnt work try to contact your ISP for some configuration.
Jun 02, 2010 | E-Machines eMachines Desktop PC
Tip
Getting 169.xxx.xxx IP address of the printer on wireles network
IP address 169.xxx.xxx is invalid IP over the network<br /><br />Go to printer front panel<br />restore network defaults<br /><br />restart printer<br />go back to front panel<br />look for printer wireless network settings<br />print configuration or network page to check if printer will have 000.000.000 IP address which should be<br />if it is then run the wireless set up wizard to connect the printer again over the network and get new IP address<br /><br />If doing above doesnt fix the issue<br /><br />Go to printer front panel<br /> restore network defaults<br /> <br /> restart printer<br /> go back to front panel<br /> look for printer wireless network settings<br /> print configuration or network page to check if printer will have 000.000.000 IP address which should be<br />turn off the router<br />turn off the PC<br />turn off the printer<br /><br /><br />then do sequencial rebooting<br /><br />How?<br /><br />1. Turn on the router<br />2. Turn on the printer<br />3. Turn on the pc<br /><br />check the wireless settings of the printer and new IP address should be given this time it should be valid one<br /><br /><br />Why?<br />by turning on the printer first router will give the very first IP address to the printer before PC huge chances for the printer to get valid IP will be possible<br /><br /><br />If still unresolved<br />contact network provider to check for security settings of router such as<br />Firewall<br />Mac Filtering<br /><br />Hope I help you a bit.<br /><br /><br /><br />Your's Truly,<br /><br />Christian from HP<br />
on Mar 27, 2011 | Office Equipment & Supplies
I purchased a wre54g range expander and have tried everything but it doesnt work
Who is the manufacturer of your wireless router?
check the IP address of your router.
connect the computer to the router and check the Ip address of the computer and the default gateway number. Default gateway is the IP address of your router. suppose the default gateway is 192.168.1.1. then open the set up page of the router . check the wireless settings of the router SSID ,channel and the security settings. Do not change the settings on the router.
If you are using WPA2 security settings them that will network on the WRE54G.
Now your range expander and the router IP addresses should be in the same range. Suppose you router IP address is 192.168.x.y and the IP address of the WRE54G is by default 192.168.1.240.
Now the x in the router IP address should be 1.
If it is, then connect the WRE to the router and open the set up page of WRE. change the wireless settigns on the WRE and power cycle the WRE and the router.
It should work
For more info about networking Click Here
Oct 06, 2009 | Linksys : WRE54G Wireless Range Extender...
I cannot set up wireless net- windows xp, wireless aterm wl54ag warpstar card, i did downloaded driver but routine setting up connection simple doesnt work,
Try setting the router to DHCP and use channel 10 instead of channel 6 to broadcast your network ID. Also, make sure you are using the correct WEP key if you have it set to use one. In Windows set the network to get the IP address using DHCP. If you have local only when you view the network double check with your ISP to make sure you have teh proper settings for the router to work with the network.
Sep 23, 2009 | NEC Aterm WL54AG (PAWL54AG) Wireless...
Router is about to get on my nerves it wont work
Have you tried unplugging the power cord from the router, waiting at least 15 seconds and then plugging it in again? This will reboot the router. Mine occasionally exhibits your problem and this solves it. You might have to turn off the PC's wireless connection and then back on (or sleep/wake up or reboot) in order to have the PC initiate contact with the router again.
Aug 10, 2009 | Belkin (F5D7231-4) Wireless Router
My wireless connection works on all the other computers allowing access to the internet. My laptop (the MSI wind U100) however doesnt connect to the internet despite insisting that the connection to the...
hi
check for the necessary ip addressing formats as well as if any DNS server addresses are required to connect to the network
if all is fine then try
right click on the network icon click on repair
try surfing if still not able to surf try the steps a couple of times
cheers
Jun 23, 2009 | MSI Wind U100-030US Laptop
Why do i keep losing my wireless internet connection?
try to have a reformat again or change the settings of your router or try to reinstall the wireless adapter that you have
May 20, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect my wireless adapter to Belkin wireless router
hi,
ok sir i got it if the wireless network is detected then try and connect and the if it doesnt connect try and connect in safe mode with networking sometimes wireless doesnt work in safe mode,but still try that,uninstall and reinstall the wireless driver for adaptor and then open the gui page(router page with the default gateway page and then change the wireless channels and also turn off the firewall,and from the start,all programme turn on the wireless adaptor utility and then start the services of wireless zero configuration from services.msc.....then if it is connected with the ehternet cable,then what u can do is that go to the router page and then also put a check in the let the windows controll the wireless network......and it will definately work and if it doesnt work then reinstall the operating system......good luck...
if it is a little bit also helpful pls.rate this soultion for me pls.....
Feb 07, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
I can not get on line
When you plug in the network cable, ensure it is plugged in correctly to the network card and into one of the router's ports at the other end. The LINK light should light up at either end (computer end and a tthe router) and flash when data is being sent or received. Then on your computer, (for Win2000/XP) go t Start, Settings, Network connections, "Local Area connection" for your card, then click on "Properties" then scroll and double click ''internet protocol' then select obtain ip address automatically. this will assign your computer with an ip address given from the adsl modem. all other settings will then assign automatically as well which should give you access to the internet thereafter. What you could also try is from one of your working wireless computers / laptop, see what IP address and gateway addresses have been assigned by the DHCP host (automatic IP address assigner), to helpyou work out where the address is coming from, it should be coming from the adsl modem. check your address by going to Start, settings, network connections, local area connection, then click on the support tab.
Apr 02, 2008 | D-Link Wireless
Open Questions:
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
