Connection problem.please check
same problem like you to another user.
I came across a PM-5 amp, and it looks like it was in a basement for a while collecting moisture and getting surface corrosion. The unit powers on, but I do not hear the speaker relay click I am familiar with on my other Marantz units. There is no output, should I be taking it apart to clean the relays. Are there relays? Should I be looking for other stuff?
Thanks
what he did.
the company tech told him.
Yes there is a relay.
Clean it and also a good idea is to clean all pots and switches.
If a relay doesn't click then it tell's you that the protection circuit is messuring a to high or to low dc-offset beyond approx 700mV + or -
black box is a relay. Should have 6 connections on bottom. 2 for coil, 2 for R&L in(amp side) and 2 for R&L out. Check DC offeset from the bottom of the board at the relay terminals on the amp side.
If DC looks good check for sound by connecting a junker speaker -ve to ground and +ve to amp side relay terminal.
thanks.please rate the solution .sir.
It's not a connection problem. All inputs act the same. There is a protection circuit, What sets it off or activates it?
I'll try what you said about the voltage and accept it. If this doesn't fix it, am I charged again for more assistance?
