Question about HP Officejet 5510 All-In-One Thermal Printer
Faxing When I try to fax, I get a message asking FAX FROM GLASS? 1+Yes, 2=No I can't fax from the top area. I have to fax from the scanner. HELP
  • chucster1738 Sep 01, 2008
    when trying to fax threw the top more then one sheet it gets jammed.
All three lights on , and cannot send or receive a fax?
Posted on Sep 04, 2008
Im trying to fax but my paper to large how the i use the top printer?
Send a fax - Use the control panel and scanner glass 1. Make sure your All-In-One is on. 2. Open the top cover. 3. Put the first page of your document face down on the scanner glass in the upper left corner. printmastert_34.jpg
4. Close the top cover 5. On the control panel, press Fax. 6. Enter the fax number, then press black or color to send.
Use the control panel and ADF 1. Load up to 50 sheets of your original document face up in the ADF. printmastert_35.jpg
2. On the control panel, press Fax. 3. Enter the fax number, press black or color to send.
Apr 08, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have new canon pixma mx 328. how to do fax operations of sending and receiving
Hi!
It is very easy
To Send Fax:
1. Place the documents facing down in the flatbed scanner glass or insert in the ADF unit with the documents facing up.
2. Press the Fax button
3. Key in the number of the receiver then press the black or color START button.
4. Listen to the dial tone and see in the lcd display the message "transmitted" to confirm that the documnets have been sent.
Using the phone is attached to your printer (documents is already load to the printer)
1. Call the number of the receiver.
2. Ask for a fax tone.
3. Once you heard the fax tone, press the Black or Color Start button
To Receive Fax (Set up first the number of calls before automatic giving fax tone to caller)
1. When someone is trying to send a fax to you, don't answer the ring on the phone, let the printer give the fax tone.
To receive the fax on the printer with the user's help.
1. When someone is calling, just press the Black or Color Start button.
To receive fax when you answer a phone
1. While the phone is lift up, press the Black or Color Start button to receive the fax.
Hope that information will guide you.
You can thank me by just rating this help.
Thank you for using Fixya.
Dec 14, 2010 | Canon PIXMA MX300 All-in-One Printer
When faxing a paper and the recipient receives the fax, their copy has a wide black lines down the side....if we make a copy, it has wide black lines down the side....we have replaced the drummer we've...
FIRST I would check the scanner glass again you can test it by asking for a report to be printed..ie tx REPORT.. if this dowsnt have a line on it the problem is either the scanner glass or at worst the scanner unit it self.. I would double check the glass.. get a soft cloth and some glass cleaner on it and give the glass a good rub over. do you have the lines on incoming faxes .. if not the glass or scanner unit is the def area to be looking at, Luck A
Aug 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Using a Lexmark 3400 series to fax
Yes your printer will send and receive faxes. 1. Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 Load an original document facedown on the scanner glass.
Here is the manual, in case you don't have one http://www.retrevo.com/d/ds/progress?doc=7d2128cd89431b0e3d4c2a1c31fa8fc4
3 From the desktop, double-click the Imaging Studio icon. 4 Click Fax. 5 Click Scan and send a fax. 6 Click Preview Now. 7 Click and drag the dotted line box to select a specific area of the preview image to fax. 8 Adjust the settings as needed. 9 Click Next. 10 Follow the instructions on the computer screen to complete the task. Receiving a fax using the software 1 Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 From the desktop, double-click the Imaging Studio icon. 3 Click Fax.
Dec 05, 2009 | Cars & Trucks
Lines on fax going out, fine receiving fax
check the scanner glass under the cover where the documents are fedd through if you lift the lid on this you should see a thin slip of glass if this has ink or usually tipex on it the lines will be on every fax that goes out.. there might be a small roller over this that has a clip each end you can take this out for acces to hte glass
Jul 31, 2009 | Brother IntelliFAX 4100 Laser Fax
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Faxing multiple pages
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
Jun 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
How to fax from glass on laserjet 3330
Use the alphanumeric buttons on the device control panel to dial the number.
If the fax number you are calling has been assigned to a one-touch key, press that key.
If the fax number you are calling has a speed-dial entry, press phone book, use the
alphanumeric buttons to enter the speed-dial entry, and then press menu/enter.
Note When dialing by using the alphanumeric buttons, include any pauses or additional numbers
that are necessary for the call, such as an area code, an access code for numbers that are
outside of a PBX system (usually a 9), or a long-distance prefix.
2. Load the document onto the flatbed scanner face down.
select YES when Send from glass? 1=Yes 2=No
appears, and then press menu/enter..
If this fixes your problem please rate this as fixed. If it didn't,please don't rate and add a comment and I'll be glad to help you further. Thanks.
Apr 18, 2008 | HP LaserJet 3330 All-In-One Printer
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark X6170
Received fax is unreadable or blurry
Please go through the checklist below to see if the suggested action(s) can resolve the issue.
* Make sure the copy function is working well.
* Print a Clean nozzle page from the Maintenance menu. If the printout has unexpected white or color horizontal streaks or missing portions, print the Clean nozzle page again. If you are still experiencing streaks or mission portions, you may need to replace your cartridge(s).
* The cartridges may need to be aligned.
* You may need to ask the sender to increase their fax quality.
Sent fax is unreadable or blurry.
1. If the receiving party indicates that the fax output is unreadable or blurry, you may want to try increasing the fax quality.
2. Check the scanner glass for excess amounts of smudges and/or fingerprints. If the scanner glass needs cleaning, moisten a clean, lint-free cloth and gently wipe the scanner glass. Make sure the scanner glass is dry before scanning the next document.
Feb 29, 2008 | Lexmark X6170 All-In-One InkJet Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
