Question about Epson Stylus 2200 InkJet Photo Printer
Response to solution one Ink pad woes
Worldvet, You are correct.There is a pad that comes up on the left to seal off the ink cartridges. I can see a tube that goes down underneath that contraption .There is also a long sponge material that extends from one end of the printing area to the other (left to right). Under it is also a white fibrous paper that also absorbs ink. I removed the top sponge layer and cleaned it. It was most dirty at the far left end. The white paper material under it is unremovable but is also very dirty at the far left end.There seem to be tabs that extend under the printer that won't allow it to be removed. Somehow the counter needs to be reset. I saw on ebay ,a guy selling a ink dispersement tank of sorts w/ software and directions on how to reset the counter but I didn't purchase it yet. i wanted to wait for your response.
alan
  • artdude08 Sep 03, 2008
    Worldvet,
    YOU ROCK!! YOU ARE A GENIUS!! OMG
    Ok first of all I'm an idiot because after I reset the counter the way you suggested ,what I didn't do was plug the usb line back into the back of the printer. DUH!!! I had unplugged it the other day when it was freaking out and forgot to plug it back in so I didn't even need to do any uninstalls or reinstalls. Just pressed the combination of keys as you suggested and BAM!! UP AND RUNNING MY MAN!!!
    You are the best dude. THANK YOU THANK YOU THANK YOU...
    I have another unrelated MAC problem  which I'll save for another day. I'll give you a break well deserved..
    Have agreat week!
    Thanks again
    artdude08
    Guru:
  • 859 Answers
There is a method to clear the counter and I think it is posted here somewhere. It is a sequence of keys on the printer control panel.
I'll see if I can find it for you.
WV
Posted on Aug 31, 2008
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers Aug 31, 2008
    Here is a link to the open source free utility to reset your printer. Just follow the instructions to install it and use it properly.
    I would appreciate if you would then change your previous rating to Fixed, if possible and of course this one too. All votes/rates amount to a status model for we experts here who work in the free area vs. the pay area alone.
    I've been running Free Clinics myself and helping in Free Clinics since the inception of the Internet in the very early 90s. Your vote means a lot to me and any others you encounter here on FixYa. We appreciate it.
    Regards,
    Worldvet
    Note: I'll be posting this in the Tips and Tricks area so others can benefit from your problem and our conversation here.
  • Glenn Rogers
    Glenn Rogers Sep 01, 2008
    Has the printer reset its counter as expected?
    Worldvet
  • Glenn Rogers
    Glenn Rogers Sep 03, 2008
    You're welcome. Thanks for using FixYa.
    Worldvet
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Pixma MP 130/110 Printer/Copier/Scanner waste ink absorber full, It neither prints nor copies
Cleaning the waste ink pads is easy.
Are your ink tanks empty and have you been using non Canon cartridges?
Regards,
Worldvet
Aug 01, 2008 | Canon Office Equipment & Supplies
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
Note
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002135/cv_mfc5460_usaeng_usr_a.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
Lexmark Printer X4270 not geting started.
1200 error was caused by a cartridge landing pad jam (Spring has come off under the ink cartridges). When the ink cartridges are parked, a landing pad moves from left to right and comes up to cover the jets to prevent ink from drying out. It locks in place and there is a spring which allows the pad to unlock and move out of the way - my spring kept coming off the post. Symptom is you can't change the ink cartridge when you open the access cover because they don't slide over.
To fix it,(complexity is 6 of 10), UNPLUG PRINTER, remove the handset (unplug cord) and rest (unslide cover underneath and pull out electrical connection, remove one screw), then remove 8 screws (2 in back 6 on top) from top cover, and remove same. Look for the spring if it's jumped. It belongs underneath the landing pad on a plastic post surrounded by a C guard. Gently move the ink shuttle to the left by turning the motor that drives the belt. When the landing pad is to the left most travel, it should be down out of the way of the cartrige movement. I had to remove the shuttle guide shaft to move the ink shuttle left but if you can coax the pad down this may not be necessary. I put the spring on and heated a flat blade screwdriver and pushed gently on the post to melt/mushroom it. The other end of the spring goes on a hook on the bottom of a pivoting catch (top of the catch looks like 1/2 an arrow and should point to the right, with the pivot shaft in the hole in the landing pad). Once reattached and with internals in operating order, with the cover off you can plug in the printer and test to see if it works, but of course be cautious of exposed electricals in the back. If successful, replace cover and handset post in reverse of removal. Good luck!
Mar 20, 2010 | Lexmark X4270 All-In-One InkJet Printer
Printer does not print a proper testprint only two or three colors printing. printhead may be damaged cleaned the printhead several times. and try to make testprints but no result.
You have an interesting printer ! I have two of them. Same problem. Basically to use ink refills one must have a chip reset utility. The cartridges are filled from the bottom and consequently leak if not sealed properly. The only solution is to use the blue grey plugs that come with some refill kits- Dell Refill kits have them - but only give you three. The next best is to use black electrical tape heated with a lighter then applied after the fill. What appears to happen is that the ink indicator may say there is ink but the cartridge is actually dry. Additionally I have found some new cartridges seem to have a vent problem - what happens is a vaccuum is created in the cartridge on head cleaning and a color will print, then not print , then the next one will do the same. Some brand new cartridges have chips also that the printer does not recognize. The solution is to use a chip reset tool and the old chip from the empty cartridge on the new one. There is a software called SSC Service Utility that works for deep cleaning and also resetting the ink pad counter - it will stop printing if the pad counter runs out. Basically if it refuses a nozzle check print - it is not getting ink or has no ink left.
Oct 25, 2009 | Epson Stylus Photo R220 InkJet Printer
Replace ink comes up, just replaced that color, can't be empty
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 24, 2009 | HP Photosmart C6280 Printer
Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Mar 26, 2009 | Epson Stylus C66 Inkjet Printer
Mp470 pixma
Do you still need help with this problem?
Regards,
Worldvet
Nov 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Ink pad woes
Sorry to be a few days in getting back to you. We had a death in the family and settling all the affairs has occupied most of my time for most of this past month or so. All is settled now, except for the memories.
As to your question, there is some variance from one maker to another and from one model to another.
I believe in your case, excess ink is carried out a flow tube to a reservoir and after printing a fixed number of times the Epson software gives you a warning message that the ink tank is full and to empty it.
Is this the case in your model? You are not seeing absorber pads?
When the print head cartridge is at rest a platform rises to seal off the print heads and prevent them from drying out. It is this platform that has the excess ink overflow tube that runs to a reservoir.
So, let me know if I'm spot on or way off base and if the later, give me a hint as to what you are seeing and what the problem happens to be. I'll be glad to help you get through this and if need be I can bring another expert into this discussion.
Regards,
Worldvet
Aug 27, 2008 | Epson Stylus 2200 InkJet Photo Printer
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Epson Stylus 2200 InkJet Photo Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
