How to activate the front panel 3.5 mm jack ??
    Scholar:
  • 136 Answers
Usually by plugging into that jack, the computer will notice you have done so. In some computers built by computer engineers after the failure of a motherboard or installation into a new case, the front panel audio connector is not installed so the front panel speaker and microphone connectors don't work.
You can see if your computer detects your front panel connections from Control Panel and clicking on Sound.
Posted on Jul 24, 2011
SOURCE:
Can I connect original Harmon/Kardon Sound Sticks speakers with a 3.5 mm headphone-type jack instead of the USB it came with?
USB speakers are a different animal to standard passive or active speakers.
The USB cable will carry power and a digital signal and the speakers have circuitry to convert this into a stereo analogue signal the speakers require.
Normal active computer speakers with a 3.5 mm jack plug obtain the power from an independent power source, passive speakers require no additional power, but in both cases they use an analogue signal from the sound card.
The short answer you wanted is no...
Mar 27, 2016 | Audio Players & Recorders
How do I open my mixer to repair the mic input jack
Gemini mixers are a hassle. You should take out all the phillips screws on the front, see if there4 are any on the side panels, and then see if it comes apart. If not, go for the screws on the back panel (the side and front /back ones). Be careful not to take out the one for the transformer (usually a big one or a nut). Peace.
Jun 09, 2015 | Gemini DJ Gemini MM-2400 4-Channel Stereo...
Remove starter 97mustang 4.6 liter
Disconnect battery, if you're doing this on the ground, jack up front of vehicle, remove right front wheel, put jack stands under frame, the two lower bolts,10 mm, are easy to access, it's the top bolt that's tricky. I use a 3 foot 3/8 extension with a shallow swivel 10 mm socket, and I come in from the front and slide the extension and socket along the inside of motor mount along oil pan and motor.you have to blind guide the socket onto bolt, remove and disconnect the 2 starter electrical connectors.
Jun 28, 2014 | 2000 Ford Mustang
Why is only one speaker working?
You can have different problems.
1. one of the wire from 3 or 4 is broken
2. one of the wire is broken in the 3.5 mm jack
3. one or two of the wire is broken in the mute speaker.
4. The speaker itself is broken.
May 01, 2014 | Juster Vintage Active 95a Multimedia...
My front panel 3.5 mm jack is not working
verify the correct jack is selected in control panel. you can also go and download the latest drivers for your pc from the manufacturer website.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 18, 2012 | Computers & Internet
I bought an intex headphone trendy it is not working with vista
i think u might have to activate the front panel 3.5 mm jack if u r plugging it in the front side of u r cabinet
it can be done from realtek driver s/w
Jul 13, 2011 | Computers & Internet
93 accord timing belt installation
  • Car jack
  • Jack stands
  • Torque wrench
  • Chain wrench
  • 3/8 inch drive ratchet
  • 1/2 inch drive ratchet
  • 10 mm wrench
  • 12 mm wrench
  • 10 mm socket (3/8 inch)
  • 14 mm socket (3/8 inch)
  • 17 mm socket (1/2 inch)
  • 19 mm socket (1/2 inch)
  • Timing belt
  • Balancer belt
  • Bottle of Liquid Paper
  • Disconnect the negative battery terminal. Using a ½-inch-drive ratchet and the 19 mm socket, turn the center bolt on the crankshaft so that number-one cylinder piston is at top dead center (TDC). You will know you ware at TDC when the mark on the crank is in alignment with the arrow on the timing cover.
  • Disconnect the cruise control connector and remove the cruise control actuator. Loosen the upper mounting bolt with the 14 mm socket. Use a 12 mm socket to loosen the lower nut then use a 10 mm socket to loosen the adjuster from the power steering pump and remove the belt.
  • Loosen the upper air conditioner mounting bolt using the 14 mm socket. Use the 12 mm socket to loosen the lower nut and adjusting bolt on the alternator and remove the alternator/AC belt. Remove the valve cover using a 10 mm socket.
  • Place the jack behind the left front wheel where the arrow is located indicating the jack location, and raise the vehicle. Put the jack stand under the subframe behind the jack, then lower the jack. Remove the left front wheel for easy access to the crank pulley. Using a block of wood atop the jack, place the jack under the oil pan and lift with slight pressure to hold the engine in place. Remove the side engine mount using a 17 mm deep socket.
  • Take off the dipstick, pipe tube and upper timing cover using a 10 mm socket.
    Then remove the timing belt adjuster rubber seal without loosening the adjuster nut. Take off the crankshaft pulley bolt. Use the chain wrench to hold the the crankshaft pulley while turning the crankshaft pulley bolt with a 19 mm socket. Use the 10 mm wrench and 10 mm socket to remove the bolts on the lower cover. Remove the lower cover and mark the location of the cam, crank and balancer shaft with Liquid Paper. Remove the balancer shaft belt and timing belt. Install the timing belt and the balancer shaft belt in the reverse order of removing them. During Installation of the crank pulley, coat the threads of the crank pulley bolt with engine oil and tighten it to 159 foot-pounds. Finally, adjust the tension of the power steering and alternator belts as well.
    Feb 03, 2011 | 1993 Honda Accord
    Model ELCHW402 40" LCD
    The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
    For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
    If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
    I hope this helps.
    Dec 24, 2010 | Element Televison & Video
    I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
    Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
    May 11, 2010 | Medion MD-1704 PC Desktop
    Logitech speakers :(
    Hi and welcome to FixYa,
    Initially, I feel uncomfortable cutting the 3 plugs, splicing them together and soldering to just one plug. What I have in mind is to use 3 barrel jacks (use stereo, the image is for a mono), splice them together and connect a single 3.5 mm plug, homemade splitter.
    Pls post back result(s). Good luck and Thank you for using FixYa.
    Jan 16, 2009 | Logitech X-530 Computer Speakers
    Computers & Internet Logo
    205 people viewed this question
    Alun Cox
