I bought a new emachine computer and can't figure out how to open the CD drive door.
    Scholar:
  • 87 Answers
Normally there will be a small raised area or a tiny button which you just press and release. It may be located right next to the door or may even be on the door itself. You may have to press quite firmly but do not keep it pressed. The drawer should then slide out. Very much the same as on a DVD player attatched to a TV.
Posted on Aug 30, 2008
Eject CD FROM EMACHINES
The CD drive has a pinhole on the door/drawer. It should be located close to the button you press to open the drive. Straighten a paper clip and insert it in the pinhole, pressing gently. The drive should open, releasing the CD.
Jun 22, 2013 | E-Machines emachines (emachinees) CD-ROM...
I am being told to stick a paper clip in the hole in front of the tray but there is no hole. I can't find the hole. Where else can I stick soomething in?
Generally there is a small hole under the tray. (The tray is where the disk sits in)
You may have a eMachines desktop computer, where there is an outer door which flips down, and the tray slides out.
Ease the outer door down, and see if the optical drive unit (CD/DVD drive) has a small hole under the tray.
If not then unplug the computer from power, observe Anti-Static Precautions, and open the computer case. Remove the Front Panel. (Plastic front of computer. Now remove the optical drive, and open it up.
I need the Model Number of your eMachines to be more detailed.
Post in a Comment.
Regards,
joecoolvette
Jun 22, 2011 | E-Machines emachines (emachinees) CD-ROM...
I emachine dvd rom/burner won't open how can i open it? but before it really do not play any dvd and then now it wont open.
If the door on your CD/DVD drive will not open when you push the eject button (on the front of the drive), Click on Start, My Computer, and Right Click on your CD/DVD drive. Then Click on Eject. If the door still refuses to open, you can insert a paper clip into the small hole on the faceplate of the drive and push it in until the door opens. If the door continues to refuse to open in the normal manner, you will have to replace the drive,
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Apr 05, 2011 | E-Machines emachines (emachinees) CD-ROM...
Emachine-new-disc door used 3 times, now it will not open. Help.
Open "My Computer".
Point at the icon for the CD-drive.
Click with the SECOND (usually the RIGHT) mouse-button on that icon.
Choose "eject", to open the door.
If that does not work, then exercise the WARRANTY on your NEW computer to get the problem fixed, at no cost to you.
Sep 21, 2010 | E-Machines emachines (emachinees) CD-ROM...
Disc slot
If you are speaking of a 3.5 floppy, you won't find one on the newer systems. 3.5 Floppys are out of date and are rarely put into new sytems. If you have data that you would like to retrieve from some old floppy disks, you will need to go to a computer store ie: Bestbuy or CompUSA and get an external USB Floppy drive. Then you can save them to your hard drive and then burn them to a CD or DVD.
Hope this helps you.
Apr 08, 2010 | E-Machines eMachines Desktop PC
I can't even figure out how to open the CD Drive on my new EMachine computer. Don't see any open/eject button naywhere?????
theres a button its hid ! on the front panel small look like part of the panel have to push it in firm and hold it just a second or two
Jan 14, 2010 | E-Machines emachines (emachinees) CD-ROM...
Opening pictures from a cd
Open My computer and then the CD Drive.Check if it is a CD problem or a CD drive problem.Try another CD to check.Clean the lens of the CD drive by a CD.
Jul 12, 2009 | Maxell CD-R 80 Minute 700MB Media...
Computer wont go past start windows repairstart windows normally
hit f8 numerous times at startup, and start in safe mode
Apr 13, 2009 | E-Machines eMachines Desktop PC
Emachine hard drive door will not open (how to repair?)
Assuming this means the CD drive rather than the Hard Drive (which doesn't normally have a link to the outside world).......
Unless something from outside is very obviously fouling the door, the problem is probably internal to the drive. With the price of replacement drives these days (shockingly low), I wouldn't even bother opening the drive to investigate what's wrong - I'd just put a new (probably higher spec) one in.
They're all a standard size and fitting and fitting a replacement is a "no surprises" job.
A.
Sep 17, 2008 | E-Machines eMachines Desktop PC
Emachines w3507 DVD Rom Broken
There may be a hole but it will be under the lip of the door, kind of impossible to get to. You may have to remove the drive from the emachine and unscrew it and open it manually with a small screwdriver. I regularly buy and repair or use parts from used samsung drives which is what emachines uses almost exclusively. The only upside to this is that once open, you can swap the faceplates and doors onto newer drives. If the led light is not in the middle then you can swap out the little plug in circuit too.
Nov 12, 2007 | E-Machines emachines (emachinees) CD-ROM...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
