Question about Kenmore 24042 Top Load Washer
Kenmore Waher Top Load
The problem I'm having is when the washing machine is finished with the wash cycle and it starts to drain the water out the spin cycle starts with the machine still full of water. What is the problem?
Thanks
  • 5,911 Answers
It is normal to have some water in the wash tub when the spin cycle starts. It will gradually drain down as the tub begins to spin faster. However, if you STILL have an abnormal amount of water in the tub as it begins the high speed final spin, you may have a slow drain problem with your plumbing, or something restricting the water in your drain pump. If you've never had drain problems before, I would suspect you might need to check your pump. I'm posting the following link that explains how to replace the pump, because it explains how to access and remove it:
http://www.fixya.com/support/r397092-replacing_water_pump
These pumps are NOT serviceable and are sealed. Do not attempt to disassemble it. You can, however look inside the pump to see if anything is lodged in it. Underwire bra hoops, socks and underwear are common items that are found. Another thing to inpsect is the back of the pump where it mounts to the Drive Motor shaft. The hole in the pump should have two flat sides. Sometimes, this hole rounds out and the pump begins to free spin on the motor shaft. Let me know if you require additional assistance. I hope this information helps you.
NOTE: If you require a replacement pump, they can be ordered ar searspartdirect.com or replairclinic.com. Make sure you have your COMPLETE model number handy.
Posted on Aug 30, 2008
Kenmore top load washing machine stops cycle wont drain water
Amber, you probably have a broken lid switch. They will not let the machine go into drain and spin because it thinks that the lid is open.
Aug 13, 2014 | Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Water continues to fill after it should have
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Tank does not drain
If the impeller is stripped , then yoes it will prevent water from discharging(completely anyway)
Dec 07, 2008 | Kenmore 24032\24036 Top Load Washer
Washer problem
Inspect the drain hose, see if there is any obstruction.
Try to understand if the machine does not drain at all or if the cycle is not completing , and timer stops before completinc cycle.
If the machine is not draining, then, once you check the drain hose and see no obstruction in there, it can be a faulty drain pump, or a faulty water level switch. If machine instead does not complete the cycle, it is a faulty timer/programmer.
See here for more detailed explanation: It won't drain
Sep 08, 2008 | Kenmore 22422 Top Load Washer
Waher wont spin
first, if it's under warranty, have them service it, if not then....
the maytags work mainly on belts with a forward and reverse on the motor. forward washes, reverse drains and starts spin cycle. if the motor does reverse and drains the water, then it's probably the transmission of the washer. these washers have 10 years parts on the transmission, so I would have a service repairman come out and fix it. you'd only pay for the labor and the transmission would be free.
Jun 21, 2008 | Maytag SAV2655A Top Load Washer
Kenmore 24042 Top Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Robert Rankin
