Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
No power Up , No Sound , No picture
Model Sony KV-32S45 no power up no picture no sound
  • 4 Answers
Im sorry tom have to inform you that a red light blinking is an indication that the main power supply is good BUT the sweep supply has a problem .. Most likly the high voltage transformer as well as the horizontal transistor is bad. if you have no solid state repair experience, you will not be able to fix this set on your own as we techs do gfo to school to learn the circuits in these sets and there are safety issues you have to know and equipment you have to have. sorry my freind but you going to need to call or take the set top a trained tech to trouble shoot as you cannot look at the board and see a problem. you have to troubleshoot the board and test the circuitry.
Posted on Sep 11, 2008
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
TV does not power-up Red flashing light
andrews electronics.
(800) 289-0301 fax
800) 274-4666 phone
give them your model number and ask price qwote on replacment power suply.
the unit sounds repairable and the board is a simple swap.
daniel.
Jan 11, 2009 | Sony KV-32S45 32" TV
Have sound but no picture
some time it works mean the tv having dry joint ( loose connection ) inside the PCB pls resolder all parts spacialy system control IC horizontal/ vertical section and power supply board as well . I think no any other issue in this tv pls resolder all part as much as possible
Jan 08, 2009 | Sony KV-32S45 32" TV
Requires careful, meticulous soldering of horiz drive circuit +
rebuild power supply.....requires four parts......Horiz out xistor,
two converter xistors and one resistor....would you like part list?
Nov 22, 2007 | Sony KV-32S45 32" TV
Sony KV32s45 sudden failure
heard a pop sound -- then the set went dead -- no lights, no nothing, and then there was a slight electrical burn smell coming from the back of the set :(
It's an old 32" set
Nov 19, 2007 | Sony KV-32S45 32" TV
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
KV-32S45 Disappearing Picture, Good Sound
yes you have a bad vertical ic . i,ve seen bad conections on this ic too, it may not need to be replace its a ic that stands up 6 pins the numbeer on it starts with TDA
Apr 19, 2007 | Sony KV-32S45 32" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
