Question about Weather King 10AJA2501AH Air Conditioner
Weather King split AC system.
My exterior one year old Weather King fan keeps blowing one of the fuses. Please help.
  • Anonymous Sep 13, 2008
    MY WEATHER KING KEEPS ON BLOWING FUSES ASLO , CHECK ALL WIRING AND CONNECTION. STILL BLOWING FUSES
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Turn the power off ,and check all the electrical connections for loose connection or wires. also make sure these are slow blown timmed delayed and not one-time fuses. Thank-you verymuch!
Posted on Aug 30, 2008
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
Car overheats and AC stops blowing cold, then temp guage eventually goes back down and AC starts blowing cold, after a while overheats again and AC stops blowing cold again. problem just started after a...
Your AC system is supposed to shut down if the engine is hot, as a safety device-make sure when the ac is running , the radiator fan is blowing-it may not be, caused by either a bad relay, blown fuse or a bad fan motor. Make sure your antifreeze is fully up to level, and if you haven't done it in the past 2 or 3 years, get the cooling system serviced with a new thermostat-cheap insurance, you do NOT want to overheat that aluminum engine, because if you do, it will be toast.
Jun 23, 2011 | 1999 Honda Accord
I have a weatherking 13AJA60A01 Ac unit and the condensor fan is not moving, I can hear a sound assuming electricity goes through the system but the condensor fan not working. The unit is just 1 year old...
Weatherking has five year parts on there equipment. You may just have a breaker kicked or tripped float switch. Check for stopped up drain Shop vac **** out stoppage from the outside drain line for unit. Check breaker. The sound you here maybe the contactor. It energizes from the tsat inside. If the contactor energizes. You have a high voltage problem. Your warranty covers aprts not labor. So call a Rheem ,Ruud or Weatherking dealer. Any of these dealers can handle warranty parts. Rusty Feadback please.
Jun 13, 2009 | Weather King 10AJA3601AH Air Conditioner
I need to fine the ac fan model 1aca3001 serie
They amke a universal fan. Multi speed reverable. Just get a 1/3 hp and use that. I only carry 1/3 and 1/2 horsepower on my truck. I have been doing service work for 45 years. Rusty
Jun 06, 2009 | Weather King 10AJA2501AH Air Conditioner
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
Not cold air cool air?
Check your air filter. if its ok call the guy who installed it and have him fix the leak. It prob is a bad weld joint. Check the joints on the copper tubing inside at the coil and outside at the a/c and feel around and see if there is oil leaking from the joint. If not you may have a leak in a coil or on the txv inside on the coil.
Aug 31, 2008 | Weather King 10AJA3601AH Air Conditioner
Weather King: model # 13AJA60A01
HEY< the compressorstart-up amps is 2-3 times the run amps. Once it gets up to speed, then the small run amps is all thats needed to keep it there! The one time fuses--assoon as it hits the rated amps it blows to protect the system, the slow-blow fuses has a few seconds to heat and blow if the amps stay to high and don't go back down below the rated amps! Thank-you-very-much
Aug 30, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
173 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
