Question about Samsung 25.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black
I have NEW sumsung ref. 25.5 french door with freezer at bottom
I hs a samsung french door with freezer at the bottom that is not making full ice cubes it only dumps 3 or 4 cubes at one time.
  • 2 more comments
  • Anonymous Sep 06, 2008
    New less than 12 hrs old, made 7 ice cubes!!!! temp set at -2 for freezer. this was a floor model, dont know it makes any difference.
  • nvg57 Nov 18, 2008
    I could not switch icemaker from cubes to crushed ice. Display showing crushed ice but icemaker dispense only cubes.
  • christyf Nov 28, 2008
    same problem, fridge is 4 months old and still only get 2 glasses of ice per evening
  • Anonymous Mar 25, 2014
    Ref is binging and cannot set temp in ref
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
Posted on Nov 07, 2008
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
May 03, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
Samsung french door fridge has clicking ice maker, what is wrong
The gear that turns the ice maker is Nylon and is most likely striped
You would be better off replaceing it with a New One, find it on ebay
Apr 28, 2014 | Samsung RF265AA Bottom Freezer French Door...
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
My ice maker is not making ice. I have checked the freezer temp it is -6, and reset the ice maker but it still will not make ice. Thank you for your help. Jim
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 30, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
The ice-maker is not making ice at its regular pace
Leo Ponder
imufo2
Jul 28, 2011 | Samsung RFG297AABP (285 cu ft) Side by...
No ice coming out of my ice maker
did you turn the water on if so when you tightened the water line you might have tightened it to tight and crushed the water line
Apr 16, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
We have Maytag 25 cubic feet stainless steel double door fridge with pull our freezer on the bottom. The fridge as stop being cooled but the freezer works fine?
There is a defrost problem. Ice builds up between the ref and frz sections and wont allow coolo air through. You can also check to see if the damper is stuck closed
Jun 13, 2009 | Maytag MFD2560HES Bottom Freezer French...
Samsung 25.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
468 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
