Question about Kenmore 22422 Top Load Washer
Topload washer agitator does not move
Washer agitator does not move, washer does not spins, does drain the water without rotating the drum.
We had a problem with spining last month, replaced a switch and everything worked well, today I smell like rubber burning and washer stoped working
  • Anonymous Dec 03, 2008
    I have a top laoding GE washer, The agitator has stopped working, water will run in the tub and run out but the agitator will not move at all.
  • 5,911 Answers
Sounds like you've already replaced your lid switch and now the washer stopped agitating and spinning, but WILL still drain water. If I'm understanding these symptoms correctly, these are common symptoms of a broken motor coupling. The burning rubber smell is another symptom as the coupler has a rubber bushing that can tears apart when the coupler breaks. There may also be a strange rattling noise associated with these symptoms too. The coupling is located between the drive motor and gearcase (transmission) and this is what transfers the energy from the drive motor to drive the transmission, which makes the drum spin and agitate. It is common for this coupling to wear out, strip, or break over a period of time. This is a very inexpensive replacement part (usually $15 or less) and can be replaced easily by the average do-it-yourselfer with a little guidance. The following link gives you step-by-step instructions how:
Some of the orginal motor couplings that came from the manufacturer were totally made of plastic. Over a period of time (especially with heavy loads) the center shaft on the coupling would strip out and the coupler would free spin. The manufacturer came out with a new improved, longer life coupling with a steel grommet. The link provides you with the new part number and where you can order the part if you wish go online. If you do not wish to order from the website, take the part number provided and go to your nearest appliance parts retailer. This is a common part they carry. I hope this helps you. If you require addtional assistance, please contact me and let me know.
Posted on Aug 30, 2008
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
I have a maytag over capacity plus heavy duty 2 speed 10 cycle washer it fills with water fine you hear the motor kick in to girate but doesent spin or you put it on spin cycle it sounds like it is...
The motor is working, but the mechanism not engaged by the helix so the shaft can not move therefore no agitation or spinning. Motor is designed to turn 2 directions: clockwise and counterclockwise for agitation and spinning. Therefore there are 2 mechanisms to assist these tasks. The drain is control by a separate pump and it is still good also.
The tube has to be out to replace the helix for agitation and a part to engage with the spinning rotation to release the brake so the spinning function can work. These parts are cheap, but the the labor is not. Hope this can help
Jan 09, 2010 | Washing Machines
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
Dec 29, 2009 | Admiral AW22 Top Load Washer
Old maytag A208 will not spin
I would say, there is something holding the inner drum from rotating. Possibly an item of clothing that has slipped between the drums.. When washing only the agitator(pulsator) moves, when spinning, the complete drum rotates as well. Remove obstruction.
Sep 21, 2009 | Maytag PAV2300 Top Load Washer
Water will not drain and drum will not rotate to spin
check your led is probably brakes off.... easy to buy and replace..unplug washer, take top conrol panel off...check your led switch...give me you email i will send you wirring diagram
Aug 29, 2009 | Kenmore 24032\24036 Top Load Washer
No Spin or agitation After move
Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
Jul 27, 2009 | GE WBSR3140DW Top Load Washer
Ultimate Care II toploading washer doesn't empty or spin after ag
Hello, I can help.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Jun 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
235 people viewed this question
Sal De
 Brian Main
Brian Main
