Question about Car Audio & Video
How do i remove the stereo from a 1997 mitsubishi lancer?
    President:
  • 720 Answers
Depending on which chassis model you have (there were two types in 1997), the most common radio mounting arrangement was behind the centre dash panel.
The centre dash panel (which surrounds the radio and possibly the face vents) is secured by a series of screws - these are usually visible and also possibly hidden behind an ashtray etc. Once you remove the screws, simply detach the panel (clips) from the dash assembly and withdraw the centre panel.
Once the centre panel is removed, the internal radio mount brackets will be visible. Remove the screws on the bracket to withdraw the radio (refer to diagram below):
Hope this helps...
Cheers,
"If this has helped you, please provide feedback"
Posted on Jul 24, 2011
Radio removal Mitsubishi Diamante
Mitsubishi Diamante Car Stereo Removal - YouTube
? 2:22
https://www.youtube.com/watch?v=smbV8n1O_fs
Aug 21, 2016 - Uploaded by Factory Car Stereo Repair
Mitsubishi Car Audio - Car Stereo Removal - Mitsubishi Diamante 1997 - 2003. Car Stereo Removal ...
* Car Stereo Removal - Mitsubishi Diamante 91,92,93,94,95,96 Car ...
www.carstereohelp.com/stereoremovalMitDiamante.htm Mitsubishi Diamante '91-96 Car Stereo Removal Guide. Mitsubishi Diamante '91-96. Car Stereo Removal*. Mitsubishi 3000GT Car Stereo Removal
Diamante Radio Removal - Mitsubishi Forum - Mitsubishi Enthusiast ...
https://mitsubishiforum.com > ... > Mitsubishi Models > Mitsubishi Diamante Jan 3, 2009 - Mitsubishi Diamante - Diamante Radio Removal - Hi, Ive seen one thread with directions on how to remove the radio, and no pictures ... Need help removing trim in order to replace radio
Oct. 27, 2011
2002 Diamante radio removal help - Mitsubishi Forum
Apr. 6, 2009
2004 diamante radio removal - Mitsubishi Forum
Nov. 26, 2007
94 LS radio removal - Mitsubishi Forum
Jun. 25, 2005
More results from mitsubishiforum.com
Car Stereo Help - Mitsubishi Replace, Remove, and Install Radio
www.carstereoremoval.com/htm/stereoremovalMitsubishiDiamante97_03P.htm Car Stereo Help - Mitsubishi Diamante Car Audio - Car Radio, speaker and amplifier - remove, replace, repair and More. http://CarStereoHelp.com Car Stereo ...
radio removal Mitsubishi Diamante Google Search
Jun 07, 2018 | Mitsubishi Cars & Trucks
Where is fuel pump located mitsubishi lancer 1997
since carburetors were replaced by fuel injection, about 1991, just about all gasoline fuel pumps were moved inside the gas tank and are electric.
Jun 29, 2011 | 2006 Mitsubishi Lancer
How do you remove the car stereo for mitsubishi lancer 2004?
depends on the unit in the car , try website ,, fitaudio.com
Dec 05, 2009 | 2004 Mitsubishi Lancer
I hae a 2002 mitsubishi lancer I need wiring radio
i dont have a pic but it goes like this..
(color1/color2 usually means the wire has a stripe or dots on it)
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
Oct 28, 2009 | 2002 Mitsubishi Lancer
Mitsubishi Lancer Need fuse box diagram, which fuse is what. My son bought this car and the owners manual was missing and he is having trouble figuring out which fuse works what. Thank you for the...
The Mitsubishi Mirage is a subcompact car produced by Mitsubishi Motors from 1978 to 2002. It was also sold as the Mitsubishi Colt or Lancer.
The following wiring diagram and electrical circuit/schematics manual provide detail information about the electrical system description, illustration and troubleshooting of Mitsubishi Mirage 1999 models: Mitsubishi Wiring Diagram
Hope helped.
Oct 16, 2009 | 2002 Mitsubishi Lancer
After a security code for a factory radio for a Mitsubishi Lancer
This is to inform you that no one could provide you the code that you need. That code is also called the 'Anti-theft' code which is unique with every car stereo.
You need to check the glove box that's in your car and look for a card. That card should carry the anti-theft code for your stereo.
If you could not find it, you need to pull out the stereo and get the serial number of the stereo on the side of it. Then call the car dealer or the manufacturer. They are the only one who could provide you the unique code for your stereo.
You would get this problem once the battery run out of charge, once the battery has been removed or once you change your alternator.
Hope this helps and have a great day!
Aug 28, 2009 | Mitsubishi Lancer Cars & Trucks
Stereo Code for 2005 Mitsi Lancer
I think you can ask the code from the mitsubishi motors where you bought your the car, they should have the code for that
Jan 21, 2009 | 2005 Mitsubishi Lancer
2003 Mitsubishi lancer es
I has this problem after i had recently changed out the stereo. Chech to see if the illumination wire that runs to the stereo is hooked up correctly. If you have an aftermarket stereo you may need to ground it to the body of the car.
I believe that the fuse is located in the engine compartment but check your car manual to find the exact location.
Aug 21, 2008 | 2003 Mitsubishi Lancer
Car Audio & Video Logo
672 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
