I need a code for an apex tv so that I can reprogram my philips universal remote so that I am able to change the channels, etc as needed. Problem is I cannot find the paperwork to get the right code. I thought it was the batteries so I changed them but still nothing but the red light searching for a code. What is that code please? CL034 is the model number, Universal Philips Remote and an Apex TV,
Need a code for my Apex DVD player so I can use my phillips universal remote
-   I had the same problem and even called APEX tech number. They said there was no codes for this TV. They tried to sell me a replacement remote for $25 and shipping was $11. What a rip off. Thanks so much!!!!!!!!!! -   Guest
2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
5. Press and release "Mute" button to install the code.
If you wish to actually identify the code once this has been done, this is the procedure:
1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
3. Press and release the "Code Search" button. The red indicator light goes off.
4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
6. Repeat again for the third digit in your code number.
trying to program universal remote control with apex digital dvd player. we already tried all the...
(More)
trying to program universal remote control with apex digital dvd player. we already tried all the codes on our list
I have an Apex 3800 Digital dvd player vhs combo but I don't have any cables to go with it, what...
(More)
I have an Apex 3800 Digital dvd player vhs combo but I don't have any cables to go with it, what cables do I need to hook it up?
my apex DVD/VCR will not come on. It is plugged in but it will not light up or allow the DVD to...
(More)
my apex DVD/VCR will not come on. It is plugged in but it will not light up or allow the DVD to eject
