Question about Jenn-Air JMC8130DD Microwave Oven
Replacing outer glass and stainless steel door on my jenn-air microwave oven
Got this at a terrific bargin online. Glass was not well padded during shipping. Delivery guy bumped it while taking off truck. glass on microwave door shattered. No other damages.
  • Anonymous Mar 28, 2014
    Instructions for removing shattered glass panel
  • Jenn-Air Master
  • 9,098 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Sep 01, 2008
Help need replace glass panel in pvc
This door is radius and would be difficult to replace. Repair clinic claims the part is due in at the end of this month, I wish you luck on your search. I have not seen someone make this correctly as the metal supports at the bottom are attached to the glass and the stainless steel outer panel is just a panel stuck to glass.
Good luck
Feb 05, 2014 | Jenn-Air Microwave Ovens
Clean inside glass door jenn-air jmc8130dd
follow your instruction manual, download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Dec 09, 2013 | Jenn-Air JMC8130DD Microwave Oven
Broken vent door/flap
Go to www.ebay.com Type: make and model of microwave, refine search to vent flap you might get lucky, if no luck, have a handyman come in and fashion a part.
May 09, 2012 | Jenn-Air JMV8186AA Microwave Oven
Lmvm2085st glass tray not rotating
The problem is most likely one or two door switches are bad, usually caused by food partical build up, replacement needed.
Mar 17, 2012 | LG LMVM2085ST Stainless Steel 1100 Watts...
Broken door on my Emerson microwave (MW8985W)
You can order the outer panel. Its available at searspartsdirect.com for about $41. Just type in your model number and look under the "Door Assy" heading. To replace, just follow these steps:
You have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and any screws that may be holding the outer panel in place. Some panels are simply snapped in place.
Remove the broken panel and install the new one. Re-install the door handle and re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you
Aug 27, 2009 | Emerson MW8985W Microwave Oven
The door glass has a burnt discolored area
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Dec 17, 2008 | Whirlpool MH7130XE Microwave Oven
Need replacement glass turntable
looking about $65 from jacobyparts.com and and sears parts
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to clean in between glass on oven door
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
I would recommend looking at those exploded views.
Sep 19, 2008 | Jenn-Air JMC8130DD Microwave Oven
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
Jenn-Air JMC8130DD Microwave Oven Logo
268 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
