Question about HP LaserJet 2840 Printer
HP Laser Jet 2840 printer
A black line runs right down the middle of the page.
  • khhokanson Jan 17, 2009
    how do I check to see how many copies I have left on my toner
  • 138 Answers
If this is happening when copies are made only and not on prints from the computer, lift the top doc feeder lid and located the strip of glass. You should be able to locate a spot of ink or white-out or something else on the glass strip. The scanner for the doc feeder moves the original paper over this strip window to scan it. A dot will appear as a line. Put some Windex or similar glass cleaner on a rag and clean the glass well. Shoot, while you have it open clean all the glass and all your copies will look better.
If it's happening in copy and printer mode (sent from computer), check the toner caridge for damage to the drum. To check the drum, simply flip open the shutter that has the HP logo and part number on it. You'll see a black tab hanging out past the left handle. Move the tag downward to momentarily view the drum. Keep the drum out of direct sunlight or bright lights as they are light sensative.
If there is a line on the drum, replace the cartridge.
Hope that helps you. If so, hit me with a FIXYA. If not click on my user name and let me know what you find so I can isolate it further for you.
Thanks.
Posted on Sep 03, 2008
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Hp Laser Jet P2055dn printing black line down the middle
The line in the middle of the page is caused by a damaged or worn fusing assembly in the printer. Here is a link to an article showing this issue on the Laserjet 2100 printer and how to replace the fuser unit. Your printer just needs to have the fuser replaced, it is part number RM1-6405 and is available from Amazon
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jul 19, 2012 | Ricoh Aficio CL3500N Laser Printer
When i use the sheet feed on my hp laser jet 2840 to photocopy the printed page has a black line down it what can i do to get rid of this?
Clean the adf scanner glass. This is the thinner strip of glass that is just to the left of the large original glass. Just lift up the top feeder and look to the left side of the glass. Clean this strip of glass with a soft cloth and some glass cleaner. Sometimes whatever is stuck to the glass is hard to get off so keep at it till it goes away. Another tip is if the line is in the middle of the copy then the "spot" to clean is going to be in the center of this strip from front to back. If the line is to the left side of your copy then the spot is going to be towards the front side.
Good Luck and Than You for using Fixya
WheatlandServices
Nov 14, 2010 | HP LaserJet 2840 All-In-One Printer
HP color laser jet 2840 feeder is broken
something might be blocking the light from the scanner lamp to fall on the originals. Try cleaning the glass covering the lamp.
May 23, 2009 | HP LaserJet 2840 All-In-One Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
HP LaserJet 2840 Printer Logo
207 people viewed this question
Ben Johnson
