Question about IC Intracom iVIEW 4-port KVM Switch
Trying to get the hot key combination for my iview 4 port PS2 switch
Hello I am searching all over the net to find the hot key sombo to change my ports on my iview 4 port KVM it is a PS 2 s/n nb7317gga0088. Can you offer any help?
Thanks
  • 114 Answers
Usually it is scroll lock and then either up or down arrow.
Lou
Posted on Aug 30, 2008
I NEED TO KNOW THE POWER SUPPLY SPEC FOR A SWITCHER I HAVE FROM IVIEW
I believe it is 9V 400ma (you can use a higher current without harm but not a higher voltage). It will almost certainly be centre +ve. You can probably use a universal regulated supply with interchangeable ends to get the correct size plug.
Jan 25, 2011 | IC Intracom iVIEW 4-port KVM Switch
Hi, I lost my iView ac/dc adapter and need to buy a new one. Can you tell me the specifications about voltage, polarity and amperes?
the switch that I have is a 4 port, (http://www.cablegear.com/156752.html) and it uses a 9-volt, 400mA A/C adapter. I do know that this type of adapter can be found on most VTECH cordless phone cradles which also has the same size DC plug.
Oct 01, 2010 | IC Intracom iVIEW 4-port KVM Switch
I am looking for the hotkey combination for our HP 336044-b21 KVM switch from a iogear KVM?
IOGEAR KVM switches uses Scroll Lock for the hot key. The models of IOGEAR KVM switches starts the letters "GCS". I don't think that your HP 336044-b21 came from IOGEAR.
Anyway, if that's an IOGEAR KVM switch, you may quickly press Scroll Lock twice + Enter (for two port KVM).
Scroll Lock twice + port # + Enter (for 4 port, or 8 port KVM).
NOTE: You need to verify the brand of your KVM switch by referring to the user manual of it.
Thank you and good luck!
May 20, 2010 | HP 336044-B21 8-port KVM Switch
How can you switch over to different computers with the Scorpius -p7 trackball keyboard?
If your keyboard and this KVM Switch are both PS2 (from the picture I see the KVM Switch is PS2 and from the Internet searching for Scorpius -p7 trackball keyboard I see it can be either USB or PS2) the connections are straight forward.
Usually a 2 port KVM switch uses keystrokes to make the switch, they are usually "Scroll Lock" or rarely "Num Lock" -- press the key 2 times with about a second or less between presses. You may hear a BEEP from the switch indicating "it's hearing your request."
Good Luck
Jeff
Mar 02, 2010 | Belkin F1DK102P 2-port KVM Switch
Key board port is not working
Try another keyboard if at all possible. Port sill not working?
You can bypass the PS2 port for your key board. You'll need to buy a PS2 to USB Y cable. Places like Best Buy have them. Here is a picture of the cable;
5bababf.jpg Hope you find this helpful.
Cheers'!
Mike
Oct 24, 2009 | EliteGroup P4VXAS (P4VXAS-R) Motherboard
Can't switch ports using PC keyboard
Make sure that your keyboard is connected to the keyboard port of the switch. The USB ports on the switch has pictures that indicates where the keyboard and mouse should be connected.
The hotkey combination is CTRL + ALT + SHIFT + Port no.(1,2,3 or 4) + ENTER
Note: "tap the keys one at a time and not at the same time"
Jun 17, 2009 | IOGear USB gcs1734 4-port KVM Switch
KVM Switch 4110 8 port
so is the KVM (control side, PS2 mouse / kbd>??)
or are all PS2 ports wired to adaptors,? i cant guess this nor what was used before, no history stated.
what was there before, this act?
and what now?
Ill assume worse cases (tossed a coin)
18 (16+2) adapters now. all devices are USB but KVM
ok.?
what mode fails, both the KVM pushbotton switch and or the hot key commands on the kbd?
Oops no manual button as seen on modern KVM.
KVMs are very complex. the hard part is the vast number of different PC.
USB , PS2, VGA, DVI and HDMI.. yah,..
OK 16 +2=18 x ps2, and 9 VGA ports. it is.
NO KVM does it all, ,, old KVM' do NOT work , on new computers, all folks know this , if they tried. or took readings to learn why it fails.
I bet power to the KVM is dead., no LED./
no manual button ,oops.
pin 4 PS2 reads 5vdc and connected up, same?
we use breakout boxes (DIY) to test ports connected.'
that Compaq is very old and no support now, no books.
why not ask at real HP, maybe some old guy there can dig it lost books>
40 KVM? that what you said, really? (or 40/8=5 kvm)?
my guess is the adaptor does not work or power issues
KVM >>PS2>>>ADapt>>> USB.(server) (usb 1,2,or 3 at server?)
The KVM in most cases, here, steals power from PS2 ports but not this KVM , its better.
i'd bet that adaptor cant do that.
(is the caps lock key working on the KBD and laser LED glowing on said mouse?
ask here, real HP.
lets see tests:
1: pin 4 ps2 5vdc?
2: mouse glows?
3: keyboard led , caps lock toggles? (glows)
4: lost the hot key commands (y/n)
one other problem is the BIOS in the server may not like your adaptor at all. When BIOS scans the keyboard. it expects a ID response if missing or grabled, it drops that device port.
https://h30434.www3.hp.com/
btw, one way to cure this, is run headless server software
end KVM for ever.
i run a LAMP server, that comes in the box, no kvm no any thing on ports. it has a web page to go to and do service that way.
port IP+:12321
modern ways work best.
in a server farm, a keyboard/mouse/monitor on rolling cart
for the super sick servers is best...
the other problem is USB only PC or server
does not scan PS2 ports, it has none
so if the adaption fails, at boot time, all is lost.
(BIOS reports connected devices to the OS)(unstated by you)so if the report fails, problems happen
for sure after the boot.
this device is s business device, now ("Enterprise)
the posts on it are like 10 years ago. all links to books now dead.
infact the compaq server that had them is turned off. (grin)
here is my search there. Why not ask them?
https://www.hpe.com/us/en/search-results.html?client=&qt=kvm+4110&search=%EF%98%90&cc=us&charset=utf-8&hpa=http%3A%2F%2Fwww8.hp.com%2Fus%2Fen%2Fhpe%2Fcontact%2Fcontact.html&hpn=Home&hpr=http%3A%2F%2Fh41131.www4.hp.com%2Fus%2Fen&hps=Home&lang=en&qp=url%3Ah41131.www4.hp.com%2Fus%2Fen+url%3ANEW+URL+GOES+HERE
Aug 26, 2017 | Compaq 242695-001 8-port KVM Switch
Want to know hot key combination to switch ports from keyboard.
Press and release CTRL-ALT-SHIFT
Press and release Machine # (1 - 4)
Press and release ENTER
or
Press and release 9 (This puts you into Prev/Next Mode)
Prev = Left Shift - Next = Right Shift
Press and release space bar to exit Prev/Next Mode.
Aug 15, 2008 | Protec Microsystems Bytelan KVM/4 KVM...
KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Jun 23, 2008 | LinxCel PS-121D 2 Port PS2 KVM Switch
Iview kvm issue...
normally will be oduble hits on left <CTRL>
Apr 17, 2008 | IC Intracom iVIEW 4-port KVM Switch
IC Intracom iVIEW 4-port KVM Switch Logo
889 people viewed this question
Top IC Intracom Computers & Internet Experts
micky dee
sonyamw
Stojan Nikolovski
Stojan Nikolovski
Are you an IC Intracom Computer and Internet Expert? Answer questions, earn points and help others
