Question about Maytag Washing Machines
My Maytag Neptune washer nodel number MAH5500B is flashing do and FL on the display screen and the door is locked and I can not open it at all.
This happened once to my Neptune. I turned it off and waited a minute before re-powering, and the the problem cleared, allowing me to open the door.
Posted on Sep 02, 2008
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
Aug 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Not locking
I had this problem also with my Maytag Neptune TL. The door lock would click multiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure either that or sandpaper will do. After that it went through the whole cycle without stopping or displaying the "FL" code.......hope this helps
Jan 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune front loading washing machine door locked, is flashing a FL and will not unlock.
I suspect 'FL' stands for 'Fault Lock'. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 31, 2011 | Maytag Neptune MAH5500B Front Load Washer
It keeps dispaling FL in the panel
Hello, the FL displaying on the panel simply means Failed to Lock. Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Solution
Check the wire connections in harness leading from machine control board to door lock mechanism
Check solenoid and door lock enable switch in door lock mechanism.
Replace responsible component..
Thanks
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Locked washer door
bruned control board will not release door open
Jul 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH5500B, FL code and door locked.
Check your drain and the drain line all the way to the pump. Here is some info on the F1 code.
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune model# mah5500b
Unplug from the outlet and wait about 5-10 minutes. When you put the plug back into the outlet, the door should unlock.
Aug 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
