Bought a new 19"TV but after hooking up cable in house and elec. it says no
Still says no signal after attaching to cable and elec.....guess I will have to go to place of purchase and see what they say since the 800 # is not available on weekends. Not sure what else to do.....cable has always worked on all our tvs,,,,don't see any other cable hookups on back of TV. thanks
Posted on Aug 30, 2008
Sansui HDLCD1908B Television
call you digital cable provider
Jul 23, 2012 | Sansui HDLCD1908 19 in. LCD TV
37" LG flat screen is
With the onset of more and more TVs being hooked up to cable, TV manufacturers didn't need to make the tuners as sensitive because the signal from the Cable Co. was much stronger than the over the air signal. If the other TVs are older they may be just sensitive enough to lock onto the channel signals. You could ask your cable provider to check your available signal in the house to see if there is the proper amount of signal. Some channels can inherently be stronger and when "block converted" (put where the cable company wants the channels) all come thru but some are a bit clearer.
Aug 28, 2011 | LG 42LG30 42 in. LCD HDTV
I just bought a Samsun Series 4+ / 440 / 450 (on the users manual lol) but when i try to hook up my DTV or PS3 using an AV cable, nothing shows up. In the Sources, it shows "AV" but when i select...
is that the av channel? if so, how do you know your getting a signal from the ps3? try hooking the ps3 up to something else to make sure you have a signal coming out of that cable (this is where you have to start) if you have another device like a DVD player, or VCR, hook that up to the AV input (or channel one as you say). if you get a picture from those devices, the problem is your ps3 not sending the signals to the tv. sorry I can't be more helpful, but that's my guess
Mar 11, 2011 | Samsung LN-T4053H 40 in. LCD Television
Just brought a new Sharp Aquos LC-40LE810UN. Every time I turn on the TV, using either HDMI or component cables, the input screen ALWAYS cycles between 480p and 1080i trying to find a "signal"...
This tv the tv Tuner signal board have intermittent interlacing scanning freqencies problem.Tv is new,u just bought this tv wright,return it get another one for the replacement.
Dec 11, 2010 | Sharp Televison & Video
Cable won't work on new tv
When I plug in all of the cables the tv says no signal. I have tried it on all different input settings and my cable provider tried sending me a stronger signal. Could I be doing something wrong and is there anything else I can try?On the back the tv has no receptor what else is there i can use?
Aug 03, 2009 | Insignia Televison & Video
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
Connecting antenna -- No Signal
Hi Shelly_Eddie,
Here are a couple of things to try:
Is the TV set to antenna or cable? Use the menu settings
Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
Reset the TV and do a channel scan, unplug and see what happens.
Let me know how you make out. Good luck.
My Website
Jan 28, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Actually it a lnt5271f, but...
Your cable line coming to the house may be fine, but each device has a section of cable running to it separately. This will be coming from one or more splitters leading from the main cable. Follow the cable line that leads to your new problematic TV, to verify that both ends of the cable are firmly connected.
If you use a cable box then send the signal to this TV, be sure you have the cable/cables correctly and firmly attached/seated in order to get the full signal strength.
Also make sure that the cable is sound and not damaged or frayed in any way from end to end.
Jun 09, 2008 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
