Paper jam light on for Lexmark E240-EL & no paper at all is installed or pieces...
  • deanshelley Aug 31, 2008
    Thank you all for your assistance & yes ''Dleahy'' a sensor was dislodged. Unfortinaly it took me quite some time to find the problom. Then I read your instructions afterwords...
    Is there any charge for your time & can I be of asistance to otheres?
    I can help out in Hydrulics, Phnumitics & Motion Control with 6-S & ISO Goverened...
    Let Me know if needed...
    Dean.
  • David Leahy May 11, 2010
    Was there a paper jam in the first place, which was cleared but the light has stayed on? Check that none of the paper sensors have been damaged/dislodged
    Scholar:
  • 113 Answers
Hi Deanshelly,
Glad to help, no charge, just rate it please
Posted on Sep 01, 2008
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
Sep 04, 2014 | Lexmark E Office Equipment & Supplies
My lexmark E340 printer displays the message: "remove cartridge paper jam" continuously and not print more pages
There is probably a sensor that is being blocked by paper that you might not be able to see easily. Remove cartridge and check the inside of the printer with a flashlight. Please turn off printer before doing this.
Sep 06, 2013 | Lexmark E230, E232, E234, E238, E240,...
My Lexmark E330 printer is showing a paper jam, but no paper is jammed.
When you removed the jambed paper, did the paper come out in one piece, if not did all the pieces that was removed make up the entire sheet of paper?
Otherwise there may be still a small piece/s of paper still in the printer which is causing this error message.
May 04, 2011 | Lexmark E330 Laser Printer
I have a Lexmark E240n printer. It keeps jamming at the same spot each time I try to print. Checked and tested the entry and exit switches. Checked good. All gears are turning smoothly. The paper jams...
does the exit switch stick up in the back of the fuser into the paper path? I've had to replace lots of the exit sensor flags because the top half was broken off while clearing a paper jam.
Apr 07, 2011 | Lexmark E240 Laser Printer
I have a paper jam in my E240 Lesmark printer.. A sheet of paper is stuck on its way to being fed out of the printer, at its top and back. On the front, the sign indicating that more paper is needed is lit...
Here's an article on How to Clear Paper Jams on a Lexmark E238, E240, E240n, E340, E342n Printer. Just click on this link: http://bit.ly/cBXKAL. This might give you an idea on what to do when having a paper jam problem on the printer. If you need further assistance, don't hesitate to contact Lexmark technical support or call your authorized service provider.
Aug 27, 2010 | Lexmark C533DN InkJet Printer
The orange light is on (second from the bottom) What does this mean? Cannot get the printer to work. Could you please tell me what the symbol means; the one with the orange light: second from the...
That indicates that you have a paper jam in the printer. You can refer to this Quick Reference: http://www.lexmark.com/publications/pdfs/e238/eng/qref.pdf. Here's an article in the Lexmark website on How to Clear Paper Jams on a Lexmark E238, E240, E240n, E340, E342n Printer. Click on this link: http://bit.ly/dbahOF. Just read the article thoroughly. If this doesn't help, I suggest you contact Lexmark Technical Support for further assistance. Thanks.
Jun 14, 2010 | Lexmark E238 Laser Printer
The symbol between the paper sign and the exclamation sign is on. this does not allow the printer to print.
That indicates that printer has a paper jam. Here's a link to the Lexmark website on how to clear paper jams on a Lexmark E240 printer. http://bit.ly/doZzSD. Just follow the instructions carefully. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 18, 2010 | Lexmark E240 Laser Printer
I have a lexmark 5470 there is paper jammed and I cannot get to the jam It is a all in one printer
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5435 paper feeder broken
Feeder goes halfway down & stops on Lexmark #5270 & would like free answer
Mar 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
