Re: How do u decrese/increase the mtu? i've been havin...
You need to access the router setup page of the router, by typing the router IP on the address of your working computer and when you're already on the router setup page there you can change the value of the MTU of the router....
Mine has been doing that lately too. Log into your router or what ever supplies internet to your xbox. Make sure the MTU is 1364 or higher. My router is set up to that and it still does that and doesn't work until the next day after about 12 hours I would guess. The xbox tells you what to do also.
This
issue occurs if your router or the gateway is incompatible with Xbox
Live, or if your router or the gateway has an incorrect MTU setting.
Note: Xbox Live requires a minimum MTU setting of 1364. We recommend
that you try out the steps shown below.
Things to try: 1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm 2.
Visit the following Web site to determine whether you have the correct
firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm 3.
See the router or gateway instruction manual for information about how
to change the MTU setting to 1364, to do this, or to determine whether
your router supports this feature, see the router support documentation
or contact support for your router device. 4. If you share a connection with a router and a modem, try a direct connection without the router.
I felt really stupid when I spent a couple hours trying to fix this. XBox Live is down today, June 16, 2009 until late tonight or early tommorow. No one's XBox Live connection is working right now.
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
what kind of router are you using to connect your xbox 360 to? usually you can define the MTU size in the router configuration.. default for xbox 360 live is 1364 ... check out your web configuration on your router to see if you can change this!
The MTU of your router or
gateway must be greater than or equal to 1365. If it is less than 1365,
you won’t be able to connect to Xbox Live.
To change the MTu login to your admin router panel:
Go to start>Run>cmd>type ipconfig
look for "default gateway" then type that address into your router login, usally the login is admin/admin if not look in your manual or call your router maker.
Now login locate the area to adjust the MTU if you cant find it, contact the router maker, or look in your manual.
More info: http://www.xbox.com/en-US/support/connecttolive/xbox/connectionmethods/diagnosingconnections.htm
