SOURCE: Sony KDF-60WF655
we had a repair guy come out and say that the ballast (power suply to the lamp) and the lamp was bad. ballast part # is 1-468-875-11 snd the lamps part # is A-1085-447-A. the retail price of both parts are $530.35 together. $195.07 for ballast and $300.58 for the lamp. with a little bit of research though you should be able to knock that down in half. he said that the ballast didn't have a chance to cool properly and is now acting in protection mode. he also said to plug it into the wall and not a surge protector. hope that was helpfull. -n
SOURCE: RCA hd50lpw42yx2 not working
There are 4 1000 mf. 35 V caps. on the AC IN pwb. (power supply) that are chronic fail items. After back is off, slide the chasis on the left side back toward you. Slide about 1/2 inch and it will lift out of track and then the chasis will be more accessible. The said caps are the tallest on the bd. and 2 are located side by side on the bottom front of the chassis. The other two are side by side about an 1 1/2 above the other 2. Most likely the top of the caps are pooched out. Replace all 4 whether they look bad or not. Problem solved
SOURCE: Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
SOURCE: Mitsubishi WD-62528 error code 45
go to the manufacture site they should tell you what the code means if not try techlore.com
SOURCE: The tv picture goes out after 20min. The sound stays on.
Is there a "sleep" button on the TV Remote Control or the TV Menu?
