Question about Dryers
Whirlpool 3RLEQ8000 Electric Dryer
Thanks to BENHAM and OLDFIXER for sorting out my problem with my Whirlpool LSQ8000 Top Loader that needed a motor coupling that had broken.
You were both spot on!! There it was broken in half. The replacement has been made more solid and has a metal insert hole.
Anyway, I have another issue.
I want to vent my Whirlpool 3RLEQ8000 Electric Dryer from the side instead of out of the back and I want to know how to remove the outer casing so as to get to the vent.
There is a circular disc underneath and on the side of the dryer that allows for the vent to either come from below or from the side.
At the moment, the vent is connected from the rear but when I push the dryer up against the wall and because of the skirting board the hose to the vent is being occluded/kinked.
I want to connect the hose instead from the side but how do I get inside the machine.
I tried removing the screws at the rear of the machine only to find that they hold the drum in place.
Do I have to remove the drum or is there a better way of takling the issue.
Hope you can Fixya me problem!!
Regards
Paul
  • diezeltruck Aug 30, 2008
    I have located a panel at the front lower section of the dryer that is held in place with clips.
    I have managed to remove the panel and it allows access to the underneath of the drum and filter mechanism.
    There is a cylindrical tube that connects to the filter vent that sits underneath the drum and pokes out the other side at the rear of the machine .
    The cylindrical tube needs making shorter which now I have removed it will allow me to cut it with a hacksaw.
    I will then connect it back up and then connect the vent hose from inside the back of the dryer but run the vent hosing so that it comes out through the side hole which can be prised off easily.
    Thanks for your reply.
    Paul
  • 31 Answers
I'm not sure about this with your machine but look low on your front panal. Most have two screws holding front panal on. Usually hidden in the character line along the base.(Clips will hold the the upper under the top...just flip up the panal it will pop off.) I hope this helps.
Posted on Aug 30, 2008
Our Whirlpool Front LOADER WILL not start. All the lights on the front panels are but the drum will not turn. I have repalced the main control panel under the top of the drum.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 26, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool front loader dryer is not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Whirlpool Washing Machines
Does not spin with large load
Being top loader try turning by hand. With light load if it runs, the capacitor would have become weak. Check the capacitor that is connected to spin relay.or check all
Mar 31, 2010 | Whirlpool LSQ8000 Top Load Washer
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool LSR5132PQO not working
Check the lid switch with a volt/ohm meter for continuity.
If no continuity, replace the lid switch.
Check the direct drive coupling on the motor.
If it will not drain, bad lid switch.
If it will not agitate or spin bad drive coupling.
Feb 27, 2009 | Whirlpool LSQ8000 Top Load Washer
3RLSQ8000 Top Loader
Make sure the lid switch is making good contact throughout the spin cycle.
Jan 15, 2009 | Whirlpool LSQ8000 Top Load Washer
the motor coupling is most likely broken. part number 285753A.
Aug 19, 2008 | Whirlpool LSQ8000 Top Load Washer
WHIRLPOOL TOP LOADER 3RLSQ8000
ck coupling between motor and gearcase ..probably broken or cracked ..remove 2 screws on back bottom of console lift console up remove lid switch plug remove clips each corner remove cabinet remove clips on pump remove 2 screws holding motor clips on remove motor clips remove motor and there it is
Dryers Logo
103 people viewed this question
Top Dryers Experts
