Trying to reformat my PC but can't get into BIOS set up.
I have a compaq presario 6410nx PC. I'm trying to do a full system recovery, but can't get into the BIOS setup program at startup. The instruction manual says to press F1 when I see the black compaq logo screen at startup but there isn't one at all, the first thing that appears is the windows XP home edition loading screen with the green bars (F1 - F10 has no effect here). And then my desktop appears after that. I remember when I reformatted it last time, there was actually a black compaq logo screen first thing at startup but now it just vanished. I don't have a clue how to get into the BIOS setup now to use my system recovery disks. If there is another way to do a full system recovery or getting the logo screen back, please reply!!!
  • Jiwe Aug 31, 2008
    thanks for the reply!! Though I've already tried that. Maybe I didn't tap it enough times...I'm gonna go try again. Thanks again!
  • 13,433 Answers
Hey,
Seems the screen is slow to start up, right after pressing the power button, keep tapping on f1 or f10 untill the bios screen or something else comes up. that will definitely get you into the bios and dont mind if the computer starts to beep, slow down a little and keep tapping.
Thanks,
Ekse
Posted on Aug 30, 2008
My compaq presario cq56 does not have a recovery system
try using boot recovery disk that u should have made when u setup youre computer ps set bios to boot cd or dvd rom and save
or try f8 in recovery mode and try it that way if not u could try the manufactures for a recovery disk or purchase a new copy of windows or try a linux boot disk maybe use full thanks
Apr 05, 2014 | Compaq Presario CQ56-115DX Laptop
I want to know how to restore mr presario compaq sr1720nx back to factory settings
There are multiple instances when you would want to wipe your PC's memory clean and reset it to the factory defaults.
Called "formatting," it is often the last-ditch effort to restore a PC to functionality.
You will also have to format your PC if it gets crippled by viruses.
Although these instructions are for the Compaq Presario, the steps are essentially the same for all Windows based PCs. Be sure that you want to delete everything this process is irreversible.
Back up any data that you want to keep by saving it to removable media, such as external hard drives, flash drives, DVD-R, etc.
Unplug all peripheral devices, except for the keyboard and mouse.
Turn on the computer. As the computer is starting, repeatedly press F1 to initiate the recovery process.
When the BIOS setup screen appears, press the right arrow key to select "Boot".
Press the down arrow key to select "Boot Device Priority" and press "Enter".
Press the down arrow key to select "CD-ROM" and press "+" to move it to the top of the list.
Open the CD-ROM tray, and insert the system recovery disk.
Exit the BIOS setup by pressing "F10". Be sure to select "Save Changes and Exit".
System recovery should initiate. If it does not, and the PC loads Windows, then you have either failed to set the CD-ROM at the top of the boot priority list or you exited the BIOS setup without saving.
Press "R" to begin the recovery process.
When prompted, select "Full System Recovery".
Restart the computer when the process has completed.
Hope this helps.
Nov 21, 2012 | HP Compaq Presario SR1720NX (EL435AA) PC...
Trying to reformat Compaq Presario CQ50
Did you create a set of Recovery discs for this machine, before you wiped out Vista and installed Windows 7? There is a utility to do this and it relies on the original windows to work. When you formatted Vista, you erased the Recovery links from the windows partition, that allows the recovery to take place. The Recovery has to 'see' the original OS to confirm it is on the correct machine. It is known as a 'fingerprint' and is checked by the BIOS to make sure it is not being Pirated. If you have the key on the bottom, you may be able to download a new copy of Vista just for Compaq machines, and it will legally activate.
Dec 02, 2011 | HP Compaq Presario CQ50-110US Laptop
I need to restore to factory setting, without a recovery disk
you can,,,
go to "start menu"
"accesories" ,,, "system Tools"
"system restore...
applied the past date that you want to recover...
Oct 23, 2009 | Compaq Presario R3000 Notebook
System recovery
You can't do it in the BIOS? Mine you F1 operns BIOS and then F10 went into system recovery. Yuor might be different but look in the BIOS.
Sep 19, 2009 | Compaq Presario 5000 PC Desktop
Need help with Restoring computer to factory setting
The system restore you are using is the windows microsoft one and is unable to do a FULL system restore.
The whole process is listed in part of the manual but just in case you cannot find them then you can get the part that you are interested in on the COMPAQ SITE
You are interested in pages 8 to10 it may be that you already have a recovery partition set up which would help you greatly.
This involves repeatedly pressing F11 whilst the computer is booting up and then selecting RECOVERY MANAGER as outlined in this manual. Then selecting ADVANCED OPTIONS / RECOVERY / NEXT.
with any luck that should get you sorted but do remember this process could wipe your personal information so get that off the computer BEFORE you do any of the above.
If you get stuck post back in this thread and I will see what else can be done
Aug 20, 2009 | HP Compaq Presario F500 F700 and G6000...
Can't extract files on System Recovery Disc 4 for Compaq Presario model 6350US
At this point, you can try to clean your disk # 4 and see what happen,
or try to make a copy of disk # 4 (if you can copy the disk) and try again.
or
1) Contact your customer support and ask for a new set of disks.(or only # 4)
or
2) Boot your computer with another OS disk (win XP)
or
3) Boot your computer with some utility disk
Oct 19, 2008 | Gateway MX6421 Notebook
How to reformat my laptop without a cd??
When you turn it on, watch the screen carefully. Many times recovery is contained on a small partition of your hard drive. When your computer begins booting, watch for a short message that says something like, "For recovery press F11". It could be another F key. You will only get a couple seconds to choose it. Choose an option that does a full restore which will reformat the drive.
Sep 13, 2008 | HP Compaq Presario v3000z Notebook
Compaq Presario won't boot
you have to reformat your pc.find some bootable disk you try window xp and reformat your pc
Dec 05, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
447 people viewed this question
David Payne
David Payne
