My wireless internet works in my hometown, but I go to college 2 hours away and plugged my Ethernet cord in. Everything says its connected, but the internet page will not load. I tried 2 of my friend's laptops and their internet works. I cannot get my internet to work. I think something is blocked because it works in my hometown 2 hours away. What can I do to fix this problem so I can get internet again?
  • 5 more comments
  • trhfoxy Aug 30, 2008
    I checked all the connections. It works on everyone else's laptop but the internet will not work on mine. Every connection says it's connected.
  • trhfoxy Sep 01, 2008
    Still not connecting.
    about 200 miles away. It's worker before when I went to school there last year. The router is in my apartment. Everything says it's connected but the page is not coming up.
    I never installed anything for the Ethernet cord. I've always just plugged it in and it used to work.
    I don't know what needs to be installed for the cord. I never had to install anything nor has my friends fro their laptops.
    It is already connected but the page does not load.
    Sergeant:
  • 241 Answers
>OK you are talking WIRELESS at HOME and NETWORK CABLE so you are using a LAN.... THIS IS REAL EASY
DOES your laptop have the Wi/Fi light on
You computer is tring to connect wirelessly
GO into you Control PANEL +Network & internet connection + Internal NIC Configuraton (3small black boxes) NOW make sure that this selected to to ALWAYS ACTIVE ON BATTERY
Posted on Sep 01, 2008
  • 3 more comments
  • Jayson Brollini
    Jayson Brollini Sep 01, 2008
  • Jayson Brollini
    YOU may also want to disable the WiFi
    this is in your IntelProset (start MENU)
  • Jayson Brollini
    Make sure that when you go back into town or you inhook the LAN cable that you Enable the Wi Fi (wireless) it is very simple and you are not changing any settings
  • Jayson Brollini
    Rate the Advise from FixYa ExpertKindofcheap
  • Jayson Brollini
    Jayson Brollini Sep 02, 2008
    YOUR PAGE WILL NOT LOAD ( this is because it is save the page from the last time you were on the Internet) it makes no difference if you are not hooked up to the NET it will always diplay this by DEFAULT. If you followed my insructions and this did not help I need to know what is the program that you use to connect on you WIRELESS.. I know that you are trying to connect with the cable.
    There is nothing to install! You just have to configure the settings>
    IF this HELPS PLEASE RATE THIS!!!!!!!!
  • 928 Answers
If you are connecting to a school network it is possible that they may have Mac filtering or IP address filtering. please inquire with the Admin regarding this.
    Genius:
  • 2,028 Answers
Try doing a system restore. You may have to go back a few restore points, but I think a restore may fix it.
  • Ryan Rogers
    Ryan Rogers Sep 02, 2008
    This is going to be a software glitch. Try the restore.
    Master:
  • 623 Answers
Go to my network places and set up a new connection
  • 4,472 Answers
Check your device manager and make sure there is nothing with an exclamation point. So are you using a wireless internet card or are you using a wired ethernet? Can you locate any networks. If not you should be able to ask the administration what the SSID is for the network so you can log onto it with the wireless adapter.
Thanks,
Lee
  • Lee A.
    Lee A. Sep 01, 2008
    You are already connected to the wireless network? and the page doesn't load? Do you have a firewall on?
    Thanks,
    lee
    Genius:
  • 1,269 Answers
First check if you have a valid IP address. Go to Control Panel > Network Connections > Right-click Local Area Connections > Properties > Look for Internet Protocol TCP/IP > Properties
Select Obtain IP Address Automatically
and Select Obtain DNS Server Addresses Automatically
Click OK all the way out, then check if you're able to go online
  • Michael Galve
    Michael Galve Sep 01, 2008
    If you are connecting wirelessly, make sure the wireless connection has a valid IP address like 192.168.xx.xx or something like that. If the IP address starts with 169.254.xx.xx, that is an invalid IP address. You need to reconnect to the existing wireless network.
    Do the following steps:
    At the bottom right hand of your screen by the system clock,
    >Right-Click on the Wireless Network Connection icon > View Available Wireless Networks
    >Click on Change Advance Settings
    >Click on Wireless Networks tab
    >Remove all the listed names on the Preferred Networks box at the bottom. Click OK
    Then
    >Highlight your network on the listed available networks and Connect. When it asks for a network key type in the password for the wireless network, confirm it on the Confirm Network Key box and hit Connect.
    If it successfully connects, that's it. You can try to go online.
  • 1,879 Answers
Dont uninstall / reinstall anything on that laptop, will cause more trouble since it was working fine hours ago.
first check your ethernet properties
  • monk3ybidzness
    monk3ybidzness Sep 01, 2008
    You-Tube video "3n89VHNPV0E" placeholder (do not delete)
    korn
  • monk3ybidzness
    check this also:
  • 1,800 Answers
Are u sure that u r installed the proper driver for ethernet/lan/wirless.
if this is not helping don't rate me so i can help u further.
Posted on Aug 30, 2008
    Sergeant:
    Champion:
  • 236 Answers
Uninstall your Ethernet adaptor. then re install the device.
If you have not entered your computer into their system (mac filtering),
you may have to go to the network administrator.
contact them and tell them that you need to have your computer allowed into the network.
Hey how ya doin, first of all is your wireless Satelite or Tower and secondly hours is irrelevant, distance in Miles or Kilometers or Metres is a factor, (2 HOURS by plane, car Train etc could put you anywhere from 200 to 2000miles away)need to be more specific. Definately contact your wireless provider or read your documentation on your providers coverage.
    Master:
  • 521 Answers
Re load the drivers of your ethernet on your pc again.
  • 6,487 Answers
If it says connected do this;
Check IP address click start>RUN>type CDM then on the block window type ipconfig hit enter if you're receiving a 169.x.x.x Ip just restart the alptop then after that try to go online and see if it will work..
Hope that helps.........
  • Mark Gil
    Mark Gil Aug 30, 2008
    President:
  • 1,263 Answers
Are you trying to bounce of another network provider other than the one you use at home?
  • Ronald Mueller
    Ronald Mueller Aug 30, 2008
    click on your net work connection. then find the availiable one that you have permission to use, meaning it's an unsecure access. if you only have secure networks availiable in the area you need a pass code in order to use that network.
  • Ronald Mueller
    Ronald Mueller Sep 01, 2008
    if it is secure network in that area you have to have a key code to gain access. if it's not then go to your network connections tab click it, then click advance tab, check your proxy settings, they should match your friends. then go back to network connections and click the repair tab this should renew your IP address and allow access. please rate this
    Master:
  • 638 Answers
First check all the connections.
I just moved in to my college dorm yesterday and you have to use an ethernet cord for internet in my room. So I bought one, and when I plug it into the wall and into my computer, the ethernet port has a...
The lights means the port is active and working. Does the lan connection show as connected on the computer, what IP are you getting if any? Does the college use a proxy?
Aug 30, 2011 | Toshiba Ethernet Cable (cmcable)
How to hook up to new computer
1.You should have a modem you received from your ISP (Internet Service Provider).
2.Plug the Ethernet Cord Into the Internet port of your router.
3.If you have a desktop computer plug in the ethernet cord into one of 4 ports of the router.
4.Open you wireless connections and connect to the internet.
Mar 20, 2011 | Belkin Basic Wireless Router
The internet icon on the NetGEAR wireless router is orange and their for will not connect me to the internet, so basically i need to turn it from Orange to green and then ill be in heaven :)
Ok follow these steps 1, unplug everything router computer modem that is running into the router
2. plug up the modem from your internet provider, wait for 3 minutes then plug the ethernet cable into the number 1 slot on the router or the one marked internet. wait untill all the lights are green then plug the ethernet cord into your desktop computer or connect to the router wireless.
Chris Thrash
B52Computers
Jan 22, 2011 | NetGear WGR614 Wireless Router
Having problems with 2wire router that keeps dropping the internet. All light are on except ethernet, does this mean the router is no good. Recently replaced the power cord which helped for awhile.
how do you connect to your router? If there's no ethernet cable plug in on the router, the Ethernet light on your router is suppose to be off. Also try to move your router 2-3 ft. away from any electrical devices like wireless phone, printer etc. because of electromagnetic interference. It may help your wireless connection to be stable and faster.
Jan 09, 2011 | 2wire (2701HG-B) Wireless Router
How to connect to the internet
You should have a home modem from and ISP (Internet Service Provider) Also If you have a router you need to plug the Ethernet Cord (the cord that looks like a Giant phone line) into the internet port of the router, Now if the router is a wireless router and you want to use the internet wirelessly you need to open your wireless connections and you will see your router in the list. Simply double click the connection and it will automatically connect for you. If you do not have a wireless router and you want to connect more than one computer to the internet,Simply keep the ethernet cord plugged into the internet port on the router and you should have 4 other ports next to each other. Plug another ethernet cord into port 1 and plug into the back or side of computer. That's it. I hope this helped have a good day
Sep 29, 2010 | Computers & Internet
Why does my computer say LAN is not connected but my ethernet cable is plugged in?
1. You possibly have lost the IP address from the ISP to your router and you will need to release/ renew the IP or you have a damaged Ethernet cord ( rare) but none the less could be damaged.
2. unplug the Ethernet cord from the connection at the wall for a few seconds and then plug it back in the wall connector.
Then try your connection. Call your ISP ( internet service Provider) and check the line to see if you have proper signal to the router.
Further instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 27, 2010 | 2wire (1000-400108-001) Router
My dell 531s wont connect to internet
Fresh install of operating system/ updated drivers may help if all else fails try to get another ethernet card and stick it in there and see if it connects..
Apr 21, 2009 | Dell Inspiron 531s Desktop Computer
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
Not getting connect
hi haloplayer 1,
Easy fix, unplug cord going to computer, unplug it from the blue spot, plug it into the black spot, plug the ethernet cord from the black spot to the blue spot.
Should work. have a good new year.
Dec 31, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
David Payne
David Payne
