Question about LG Dryers
LG dryer model DLE0442W...brand new. no heat. had the thermostat replaced. it worked while the repair guy was here. put a load in and left for the day. came back and the load is wet. now it won't heat again.
  • 31 Answers
Hi, I'm not sure this will correct the problem but check to see if your dryer is properly grounded. It should be grounded to the cold water pipe.
It does sound like the thermostat would be the problem. I'm not sure why it is failing. Sorry I couldn't be more help.
Posted on Aug 30, 2008
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
Dec 21, 2012 - Uploaded by
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
LG dle0442W won't heat
This is the steam dryer with 9 drying programs, right? My sister has this one. I have 2 options and will start with the easiest:
1. Unplug it. Leave it unplugged for about 5 minutes. Then plug it in and see if this reboots the computer.
2. Second guess is your thermostat. They are not that expensive to buy the part and pretty easy to swap out. Just unplug it, obviously, and remove the back panel. Inside the panel you should have a 'roadmap' of the insides. Really easy to swap out.
Do try the rebooting the computer. Seems like all my new appliances need that swift kick when they act up. Darn computers.
Best of luck.
Feb 28, 2015 | LG Dryers
I have a LG Tromm dle0442w doesn't heat blow out cold air
It is caused by three possible candidates:
(1) The thermal fuse
(2) Heating element
(3) High limit thermostat.
Have these devices checked out and replace the faulty part.
I have a 2 year old LG DLE5001w dryer. It stoped heating heater element replaced on 11/21/14. Worked 2 loads stopped heating, replaced switch, worked 3 loads stopped heating replaced thermostats. Did
Most Dryers has a thermal switch that when the air flow gets so hot it will shut down the dryer until it cools down or on some models the thermal switch has to be replaced .. The most common problem to cause this is a restricted air flow somewhere in the exhaust of the heated air causing the dryer to reach too high of temp, which could cause a fire .. Hope this information is help full......
Dec 29, 2014 | LG DLE5001W Dryer
Need to remove front panel of dle0442w to get to heat limit switch
unplug the dryer,remove the top panel,remove the control panel,usually a couple of screws on the top right and left side,when you get the control panel off there are like 4 screws on the top front panel then open the door and remove 2 more screws,disconnect door switch.go here this will help you out i'm trying to go by memory and it's harder to remember how to do it,when i'm in front of it i can pull it apart no problem but this should help you out.
Nov 08, 2013 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
Dryer not heating
Hello Krazy
If your dryer tumbles, but there is no heat. You need to check this following:
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Best Regards
Neciforo Llanto
Sep 30, 2013 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
LG DLe0442W Dryer working but no heat at all.
Check the heating element. That is were the fault is coming from.
Jan 09, 2012 | LG DLE2532W Electric Dryer
Kenmore Dryer will not start
my kenmore dryer 80 series wont start the start switch just buzzes and the drum does not turn i put a new switch today vacuum it and check all belts they seem fine dont know what else to do
Jan 08, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
282 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
