Question about Gevalia CM-500 12 Cup Coffee Maker
Gevalia CM-500 12 cup problem.
Unit has stopped working. Lights come on (red on) and is not problem with timer (has cycled). Unit does not heat water or heat base. Had about three intermittent starts where pushing on/off button got it to work, but that too has stopped. Took apart and believe the heating element in the bottom is finished.
Plugged in and turned on power (red). The element did not heat at all.
Connections look to be in good shape, no corrosion or evident breaks. Appears that the water and base are a common heating element. Like the unit and would replace the element if that sounds like it's the problem.
Can reply to scott.morford@comcast.net
  • 8 more comments
  • lv2gig Oct 20, 2008
    Same Problem. Is it repairable, or do I have to ditch the unit?
    edgoldberg@comcast.net
  • Anonymous Oct 25, 2008
    Yep, used it once and the heating element broke.
  • Godsman3712 Nov 06, 2008
    My Gevalia Kaffe CM 500 Coffee Maker has now stopped working. The red light still comes on and the clock/timer works, but the wates does not go down. It does not heat up or perculate at all. What is the problem? I called Gevalia Kaffe and they don't even have a tech support team. I can't find my manual so I don't even know how to trouble shoot this problem can some one please contact me quickly.
    Sincerely;
    Coffee Lover.
  • FixYes Jan 18, 2009
    Can you "Jimpofic" contact me and tell me if it is possible to replace the FUSES you are alking about posted on your Solution Thread !? my e-mail is bijan3@aol.com or call me (better) 713-447-5937
  • jsmiller Jan 21, 2009
    I have checked the thermal fuses and they have continuity so they are good. How do you get the top off to check that out?
  • subodhn Jan 26, 2009
    If any Gevalia CM-500 user discarding it, I will appreciate if I can get the filter basket assembly and will pay for the postage. My machine's drip valve has broken that sits below the filter basket. It has 3 parts - one valve, one spring and one sealer washer.
    Thanks so much!
    Subodh
    subodhn@hotmail.com
  • SaltLoaf Feb 21, 2009
    Having the same issue - unit turns on but the water never heats up or brews.
    Coffee maker turns on, but water doesn't heat up or brew.
  • Anonymous Apr 21, 2009
    fuse
  • Anonymous Apr 25, 2009
    Cheap unit.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
Posted on Dec 02, 2008
  • Doug Main Mar 29, 2011
    Maddog is asking 'and what year was this problem?' Tried to help and then found these 'gazillion answers'. I wonder, WHY I should bother? but it is neat to see you guys' helping each other out. Good Luck to all.
Jimpofic is correct about the temperature fuses. I replaced the one on mine that had blown.
I ran a pot of water through to test the coffee maker. Although the heating element works, it seems that the coffee maker is still having issues. It perks about half the water, then seems to "overheat" the water and it sounds like it's finishing perking the whole pot. The second pot of water only got to about 4 cups then "overheated" the water and sounds like it's finishing perking the whole pot.
It appears that the temperature fuse blowing is an indication of an element with a "hotspot", or it is simply getting too hot to properly perk coffee. It could be calcium built up in the water tube of the heating element, I didn't disassemble it to try to look, or clean it out.
So, after a couple bucks in parts and way too much time spent on fixing my two year old coffee maker, I finally went out and bought a different one. Problem solved.
Posted on Feb 09, 2009
Connections look to be in good shape, no corrosion or evident breaks. Appears that the water and base are a common heating element. Like the unit and would replace the element if that sounds like it's the problem.Can reply to mar9cal@aol.com
Posted on Jan 28, 2010
Water not heating
If it's full of water & the red light is on, check if the maker is heating up the warming plate..if not, odds are you may have a bad heating element. Brewing cycle won't start without it.
Apr 06, 2014 | Gevalia CM-500 12 Cup Coffee Maker
I have a Gevalia Kaffe 12 Cup Automatic Coffee Maker (Stainless Steel) Model CM-500B (Black). Date Code: S1710. (Global Marketing Corp. warrants the coffee maker, thru Gevalia) It worked perfectly for...
Hello, point
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 19, 2011 | Gevalia CM-500 12 Cup Coffee Maker
Our office has a Gevalia Deluxe coffeemaker. It
Most likely the cycle thermostat that turns off the heating element has failed. It is supposed to reset after the it senses the water temp below 130 deg. If it did not reset or has failed it will not turn on the heating element but the clock will work fine.
By the time you ship the unit to a repair center with parts and labor and get it returned to you the cost would be as much as a new unit.
Thanks for using FixYa.
Kelly
May 13, 2010 | Gevalia CM-500 12 Cup Coffee Maker
Xcc-12 gevalia coffee pot wont brew.
Thermal link open. Located in base of unit mounted against the warming pad heating unit.
Oct 28, 2009 | Gevalia CM-500 12 Cup Coffee Maker
I have a broken pot for CM 500.
I have a brand new carafe White for the Gevalia white for sale contact me elfnts@juno.com
Oct 27, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Need instruction manual
To download the instruction manual, please click on the link:
Gevalia CM-500 Manual
Sep 29, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Operating instructions
I have this manual (CM500) and can scan/email it to you if you send me your email address...also I am looking for a replacement lid for my carafe for this machine if anyone is looking to get rid of theirs!
Mar 29, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Open Questions:
See all Gevalia CM-500 12 Cup Coffee Maker Questions
Coffee Makers & Espresso Machines Logo
3,832 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Kolbrun...
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
