Question about E-Machines eMachines Desktop PC
No sound i change my hard drive and i no have any sound, i need some help
  • David Leahy May 11, 2010
    If you go to "control panel-system-Hardware-Device manager" are there any yellow "unknown devices"?
It won't turn on.The button thats usually red or green isn't on. Tried different outlets.Just bought last month.
Posted on Aug 30, 2008
  • 200 Answers
Ok my friend seems that you have issue with the sound driver
go to this website.
select your computer model
download the driver and enjoy the music
How to access my Buffalo HD-PNTU3 external hard drive?
dropping it while turned on is fatal as it usually damages the write heads and/or the platters.
if it hit the floor, changes are it's physically damaged the mechanism.
recovering data from a drive with this damage is not cheap as you will have to send it away to be rebuilt. It's impossible to rebuild it yourself.
Feb 21, 2016 | Buffalo Technology Buffalo MiniStation...
My WD element extrenal hard drive won't open. i can see it in my devices, and the blue light stays on. it also makes the sound saying it's connected but I can't see the device in my comput
First thing, try to change the cable, try a different one, then if it does not work, try to connect the hard drive on another computer, and changing cables as well. This will help you to narrow down the problem to find out exactly what the matter is. If the Hard drive spins properly and it does not produce any click-click sound then it is fine. If all the above fail, then you have to slave the hard drive using its internal SATA connection. You have to open up the hard drive and remove the pin that connects the hard drive to the cable. This will enable you to see the SATA connection. Slave the Hard drive on a desktop computer and see if you can gain access to it. If you can, then consider replacing both the cable and the pin that connects the cable to the hard drive. If your hard drive just spins and you can not access it while its a slave to another computer, then the hard drive has a problem.... Try the methods above, i believe your hard drive did not go this bad...
Mar 26, 2012 | Western Digital Elements powered by WD 320...
My simpletech 500GB hard drive isn't working anymore. Everytime I turn it on it makes a wierd sound and then nothing.
what does it sound like? might be trying to get power to it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Aug 30, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Hard drive tries to start but makes only a clicking sound and then stops but green light stays on
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered suction vacuum cleaner or a fine air blower from a air compressor making sure there is no MOISTURE in the air lines then give the hard drive a firm tap on the side to free it up
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive also you might test your PSU power supply unit if this is faulty can cause lots of problems
hope this helps
Dec 01, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Hard drive not being recognised now.making clicking sound
The clicking sound is very bad, i would suggest that you backup the info you need from the drive emmediately. The drive is crashing, thats what making the clicking noise. Hope this can help you.
Best regards
Oct 28, 2009 | Computers & Internet
Hard drive does not get up to speed, not recognized by computer. has a sound that is not normal to a hard drive. there is a click sound about every 10 seconds, after a minute or two the sounds stop and...
You need to backup everything on that drive now while you can. It will quit forever soon.
Hard drives go bad quite often, Get a new one soon - but DO NOT WAIT to back up what you can now.
Jul 17, 2008 | Computers & Internet
Sound Problem...
Mar 31, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hard drive crash
Your hard drive has crashed but here is what you can probably try. Take off the hard drive. Put it into another system (a friend's computer or something) as secondary drive. See if it gets detected in the BIOS. If it does, you can try and run a application like Recover my files to try and salvage your data. Hope this helps.
Dec 26, 2007 | Western Digital My Book Essential Edition...
E-Machines eMachines Desktop PC Logo
27 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
