Question about Canon Office Equipment & Supplies
My canon ip1800 will not allos the paper to feed it keeps telling us the paper is out but each paper that feeds has a small crimp on it like the roller is not taking please help
    Master:
  • 623 Answers
Clean your printer and try this:
click start
right click my computer
properties
hardware
device manager
?ports
scan for hardware changes
Posted on Aug 30, 2008
  • Canon Master
  • 13,433 Answers
Hey,
Open your canon properties, goto maintenance and select Roller Cleaning.
Let me know how it goes.
Thanks,
Ekse
  • Canon Master
  • 6,487 Answers
The paper pick up roller is dirty that's why it's not picking up the paper, get a small bottle of rubber renew and some Q tips dip the Q tip and turn it sideways and rub it on the pick up roller to clean put a bit of pressure and make sure you get the whole pick up roller you will see it get lighter in color when it's clean, be very carefull not to get the rubber renew on the printer it will eat the plastic.
Hope that helps.........
    Master:
  • 638 Answers
Yes .its the problem of gears which are pulling the papers.clean that rollers.simple.thanks.for this easy question.
  • hemant somaiya
    hemant somaiya Aug 30, 2008
    if the gears are faulty you have to replace it.but cleaning will definately work.after cleaning apply the greece material on the gears to make it run fluently.thats it.done.please do rate the solution.
Paper not feeding through properly, then jamming.
try to clean the back part of the printer.... maybe there some dry molden ink... that make your paper jammed
Aug 30, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 will not feed paper...One side jams and when I take the paper out, the jammed corner of the paper is folded under.
canon has a friction feed system,
clear the paper path and check if there are any small paper peace,
clean the pickup roller by a waterized cloth,
proper set the paper guide and try print again.
Jun 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The same problem with my ip1800
Hi There, if you go onto the top of the page on this website and type in manula for canon ip1800 it will bring up the manual and it will show you how to fix it.
Jun 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer either eats up paper or won't print anything out
what you might try is to find some thing that has been laminated on both sides and manuall feed it in to the feed rollers and see if you are able to push out what ever is in the paper path making your paper go in crooked. brother tech
Jan 17, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma mp150 saying paper jam but cant see one
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800
your paper feeder has lost some parts..open up your printer then look for the round paper feeder that has a rubber on it.you will find out that there is a small plastic that has been broken.get a screw or any kind of metal to replace it.
Aug 02, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper not feeding right
Hey. I too am having that problem with my ip1800 canon printer. It makes a weird "clicking" sound whenever I turn it on, and then when I try to feed it paper, the sheets either get stuck and become crooked and cumpled. OR, when it does sound like its printing, it doesn't print on the page--maybe the tip of the page, but not the whole page.
May 02, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
120 people viewed this question
old marine
old marine
