Question about Whirlpool Washing Machines
I have a whirlpool model lsq8520jq1 that will not drain it agitates then stops I have replaced the pump and still does not drain
  • 5,911 Answers
If your washer fills, agitates, and then when it gets to the rinse cycle it just stops, this is a common symptom of a lid switch malfunction. The switch may be loose or not making good contact. Often you can solve this problem without requiring parts.
As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it.
Both parts can be found at searspartsdirect.com. Just type in your model number and the lid switch will be located under the "Top and Cabinet" heading as item number 11 (part #3949247). The lid strike is listed as item 20 (part #358684). You may also check repairclinic.com. They carry the SAME parts and sometimes offer a better price. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
This is a simple and inexpensive repair if you wish to accomplish this on your own. The total repair cost for this job will run you about $40. I hope this helps you. Let me know if you require further assistance.
Posted on Aug 30, 2008
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer won't drain i replaced the motor and timer its a model LSQ8520JQ1
you forgot the pump. remove pump and look inside or it for objects and the hoses that connect to it. if you can. blow thru them to see if they are clear.
Feb 11, 2011 | Whirlpool Washing Machines
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
My whirlpool washer agitates but will not pump out the water. I thought the timer switch assembly was bad so I replaced it. Still no water pump. I can not find the Model Number tag on the washer...
Drain Pump Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Aug 03, 2017 | Whirlpool LSQ9520L Top Load Washer
Whirlpool LSQ8520JQ1:Unable to separate agitator
NO.............remove the cap as you have done and you depending on this model need a 1/2 square drive like a socket extendsion... then using the driver attached unscrew the inners will turn counter clockwise. after it unscrews the upper part of the assy can be made...
Nov 28, 2009 | Washing Machines
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not spin or agitate. Pump works.
First, see the following Whirlpool Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If it drains and you can hear the motor trying to turn the transmission for the agitate mode, the obvious first answer is the Motor coupler. I'd replace it just to be sure.
If it's not the Coupler, the problem points to the transmission itself.
There are only two components of the gearcase that are used for both agitating and spinning.
One is the Agitator shaft which drives the agitator and holds the spin pinion that drives the clutch for spinning.
The other is the main "Bottom and pinion gearcase" itself.
Please see the following Whirlpool parts list for commercial top load direct drive washers although the consumer models use the same transmission parts.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 24, 2009 | Kenmore Washing Machines
Whirlpool washer model #LSQ8520JQ1 won't spin or drain
there is a possibilty the drain pump maybe locked up by a small foreign object such as a small nail tooth pick drill bit or even a coin check that.if that does not solve them problem then the timer or control board may need to be replaced
Sep 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De
