Question about Jl Audio 500/1 Car Audio Amplifier
Fuse keeps blowing
Hi ya. the inline fuse keeps blowingunder the hood the secound the amp is switched on how can i fix this
  • 631 Answers
The amplifier probably has shorted output transistors. If the amp only blows the fuse after remote voltage is applied, the damage may be minor. They generally blow two transistors. Sometimes that's all that needs to be replaced.
Let me know if you have any other questions.
Posted on Aug 30, 2008
No power to dash or crank
It's pos to be an ign switch but before throwing a lot of expensive parts at it before ya fix it I would check All the fuses & relays first, & they're a lot of them an Caddys. Under hood, under dash, under rear seat, if battery is under seat a lot of fuses & relays are there too, (but probably not for these issues). Check anything labeled IGN or ignition switch, or for any system that isn't working, dash/cluster, starter. If the fuses & relays are good then get a test light & start checking from there.
Mar 06, 2013 | Cars & Trucks
Battery dies
You have a bad relay. The relay is in the fuse box under ya hood. Look at the cover and it will tell you which one it is. If i'm right it will be the secound one down on the left. Change the relay and it should be fine.
Nov 25, 2012 | 1991 Ford F250
I have a 2002 Toyota corolla T sport 1.8 and have just had the engine rebuilt but it keeps blowing the 15 amp audio fuse under the bonnet, have tried putting a big amp fuse in and still blows. Car starts...
Who installed the engine? If you did, check all the Grounds/Earths under the hood/bonnet. If the mechanic/shop did, take it back and have them fix it.
Td
Nov 21, 2012 | Cars & Trucks
My stop hazard fuse keeps blowing on my 95 chevrolet k2500 Cheyenne. I do not have cruise control. i have disconnected the break relay and my turn/hazard switch. It still blows, yet when i unplug my break...
check the AMPS for all your fuses sometime a low amps fuse in the wrong slot can blow otherones. also sometime you can increase the fuse that keep blowing. try that first if that do not work you might need to run and electrican test on your fuse box to check if you have a short. also check your fuseable link on the fuse panel under the hood.
Nov 13, 2010 | 1995 Chevrolet K2500
Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Jul 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Keeps blowing the prime fuse under hood,gas gage won't read,heated seats won't come on,after truck starts,blows that fuse each time.Problem just started.
this problem is most likely caused by a fuel pump with high amp. draw on start up.use a amp meter.then replace fuel pump.
Oct 23, 2009 | 2003 Chevrolet Silverado 1500
Fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Jun 17, 2009 | Garden
Keep blowing fuses under hood.
REMOVE THE FUSES ONE AT A TIME FOR EACH ITEM ON THE 50 AMP CIRCUIT. I WOULD START WITH THE POWER WINDOW FUSE FIRST. IT WOULD BE THE MOST LIKELY SOURCE OF A HIGH VOLTAGE DRAW. THEN GO ON TO THE WIPERS AND SO FORTH.
May 29, 2009 | 1995-1997 Chevy Tahoe Ignition Starter...
Keep blowing fuse under hood when i put power wire in to amp
disconnect the negative battery terminal, replace the fuse with all the wires hooked up to the amp and reconnect the battery terminal, that way the initial surge of power goes through the negative terminal and not your inline fuse. That should solve your problem.
Mar 29, 2009 | Pioneer GM-5200T Car Audio Amplifier
100 Amp fuse keeps blowing
Fuse MAIN - protects the following circuits:
Power Distribution 58880347
Jan 01, 2009 | 1994 Ford Escort
Jl Audio 500/1 Car Audio Amplifier Logo
170 people viewed this question
Top Jl Audio Car Audio & Video Experts
Alan Desotell
Alan Desotell
Level 1 Expert
matthew walsh
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
