The heater was working fine when we went to bed but in the morning we got up to find it had stopped working even though the thermostat showed the heat to be on.We checked the pilot flame and it is on.It is a reverse cycle Brivis Buffalo system(1984) model.The fan is alo working fine.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This is too deep to explain, so its best to call a service tech, with all his diagnostic tools Thank-you-very-much!
Posted on Aug 30, 2008
The fan on one my central heating and air unit won't come on? It was working fine when I went to bed at 1:30 in the morning and when I got up around 7:30 this morning it wasn't running anymore.My house has...
Running the equipment on 72 degrees would cause the compressor and fan to work harder on hot days. This will definitely place more strain on your capacitor. These capacitor problems usually happen on the hottest days. I would suspect the capacitor, not the fan. I'm an HVAC tech, so I would Check both with my multimeter
Aug 25, 2013 | Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
Premier Plus Model#MHE62-30H-045DV Ser#45T421608 I just purchased this hot water heater.I had it professionally installed by a plumber.We had hot water before I went to bed but when I woke in the morning...
sounds like you have a power problem. or worst than that a leak . So lets look at the leak first. Turn off the water supply at the water heater on top. This valve should be on the cold side of the heater on top.
Turn it off, check and see if you have pressure in the house by turning on a faucet. It should run for a second then stop. That is good if it does. Leave the valve off on the heater and check that your breaker is on. Reset the breaker by turning it on and off.
Wait about 2 hours turn the heater back on and check to see how hot the water is hot then you might have a leak in the building. If there is not or little hot water. Check the wires where it connects to the water heater. You might only have one wire that is connected right.
The best thing to do is to get a amo meter and check to see if you have 220 if you dont have 220 you will not warm up the water the way it should.
Thanks Richard
Sep 07, 2011 | Premier Water Heaters
Wall heater will not work, even with thermostat in on pisition
Your thermocouple may be shot.
Have ya try to replace that one?
A simple thermostat now let me show ya a video of a man that has replaced his thermostat. Even though that gas valve is a bit different the thermocouple does the same function and that is hold down the safety magnet. Now watch:
Replace that thermocouple on your heater.
Feb 18, 2011 | Williams (5009622) Ceramic Gas Wall...
This Morning I turned on my heater (to auto) after changing my air filters and it went on and when it clicked off and i tried to turn it back on it stopped working, the thermostat works and i changed the...
Make sure the panels are put back on securly, the door safety switch may not be depressed. Also check the circuit board in the heating system for a blown fuse.
Nov 23, 2010 | Honeywell Programmable Thermostat Heater
I've just moved into a home with an existing Armstrong Concept 10 A/C unit that's at least 15 years old. When I left for a 2-week vacation, the unit was working great. I set the thermostat to 77 to save...
Hello 93 The compressor caused the breaker to trip.A weak capasitor or burnt wire is a common cause.It sounds like the compressor is NOT on even though the fan is.It may need a new wire or maybe a HARD START kit to help restore operation.Call for help.HS kits are not expensive.NO damage results from leaving it on, the problem would have happened anyway even if you went on vacation or not.The curcit breaker stopped it.Its worth fixing.
Aug 30, 2010 | Heating & Cooling
Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Sansa fuze 2gb wont turn on or charge
Mine did the exact same thing, (Even the going to bed thing) I'm glad you posted your question. Incidentally enough after trying to turn-off and on for ten minutes, I pressed all the buttons a whole bunch to show it my frustration.....then it worked. (?) I don't know why, but I think that the computer going into hibernation or shutting off affected it.
Jun 23, 2009 | SanDisk Sansa Fuze MP3 Player
Cozy Heater will not turn on from thermostat in the morning
no more than 20 feet of statr wire allowed and make sure the stat you have is for a millivolt system.
Dec 03, 2008 | Cozy Enclosed Front Console Heater 70,000...
Heating & Cooling Logo
386 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
