Question about Soltek SL-PT880E-RL Motherboard
PCChips M848A Motherboard
I have the same problem you had with no video. Did you ever get your problem solved?
Thanks,
Doug
  • 1 more comment
  • Anonymous Sep 14, 2008
    can get video to work???? any ideas
  • dougbriggs
    dougbriggs Sep 17, 2008
    I have put in a working PCI card and still no video. I RMAed the unit back to NewEgg and the new unit works. It seems that the comments I've seen about PCChips MBs are true. There are lots of DOAs. Mine has now been running for a week without trouble. The original MB failed because of lack of ventilation. Needless to say, I added case fan on top of the one on the processor and in the power supply.
  • dougbriggs
    Xtom, What do you think of FoxConn MBs? or better yet, what brand of MBs do you recommend? I'm not looking for bleeding edge, just reliable boards that will let me run a few server and workstations for my business on the cheap. I provide SOHO network services and want to keep a variety of systems running for testing, education and emergency replacement for clients. Thanks in advance.
    Doug
Fffffffffffffffffffffffffffff
Posted on Sep 17, 2008
    Sergeant:
  • 293 Answers
Ok well the simplest answer is to get ahold of an old pci (not pcie) video card and plug her in. If this doesn't get you video I don't know what will. If you're not getting vid with the pcie slot it could be disabled (idiotic I know) in your bios.
Posted on Sep 01, 2008
  • Kristoffer Martin Sep 17, 2008
    Well we do say, "Stay Away from the PCChips motherboards, hard drives, ram, and ide bays."
  • Kristoffer Martin Sep 19, 2008
    Stay way from Foxconn as well, they are worse than PCchips. You'll RMA your *** off. (and before you ask the same with Jetway). Good motherboards are elitegroup, Asus, Intel, and MSI. Always read the user comments too. They tend to be the truth about the motherboards. As for making a server, I'd actually go with a MSI 915G (which is what I'm running) its not that far out of date, is capable of great expansion, and has IDE Raid functionality for backing up your system.
    However, Newegg has alot of great options for server based motherboards. In the 75-100 dollar price range they currently have Asus and Tyram. Now I know Asus is superb but I'm not so sure on Tyram. All of these are AMD Opteron based processor class. You can get these fairly cheaply as well. You'll just have to do your own research as to which motherboard is for you.
    If it is a server you're looking for, pay attention to processor functionality (dual slot versus single cpu slot, will it run on just one slot even if it has two. Ram expandability, PCI slots etc. Pay special attention to SATA versus Legacy hard drive connectivity.)
Update for SiS 2615 Display Adapter to load windows XP pro
The PC Chips MB PCCHIPS SiS746FX M848A V5.0 462 motherboard does not have onboard video, correct? So if you can obtain the make and model of your video card, you can then find the Windows XP drivers online for download. Then you would be able to provide said drivers when the "system asks you to update SiS 2615 Display Adapter driver"
*Another quick fix would be to use a different VGA card, if you have one available?
*Now, I have never been prompted to update display driver before or during a windows installation or update. So that step I would require a little more detail on. I have only been prompted for mass storage drivers (as seen in screenshot).
Apr 19, 2010 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Compatibility of Radeon HD4770 with PCchips a15G motherboard?
i is supported... the alternative card is nvidia GTS 250, XFX GTS250 1gb cost ~rs8500
Jan 17, 2010 | PC Chips PCChips A15G Motherboard - v1.0,...
I need a wiring diagram fora M848A motherboard
Hey compu_suppor,
Good Luck finding a schmatic of the board. I'd contact PCChips directly and see if they even published one. HERE's a least the manual wih their info you contact them.
Good Luck
Mark
Oct 17, 2009 | PC Chips M848ALU Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Hi i have a problem with panel1 on M848A v5.0 motherboard i cnt seem to work out how to connect the case properly it looks like this ()()()() ()()()()() i have the power switch, reset switch, hdd led and...
OK, this is for all the idiots who reply and offer NOTHING. You need more info, model and ver? HE ALREADY GAVE ALL THAT INFO.
Type "M848A v5" in google and you will see it is a PCChips mobo AND the manual is here:
http://download.ecsusa.com/dlfilepcc/manual/848Av50.pdf
BUT the manual DOES NOT HAVE THE PIN-OUT, so the manual is worthless...
Here is the pin-out:
(2)(4)(6)(8)
(1)(3)(5)(7)(9)
...and thanks to guntotenmadm
Aug 28, 2009 - The pin layout on the MB are color coded. There is green, orange, pink, and blue. I'll start with the green pins 2 and 4 these are for the power led wires, bottom pin #2 is the + pin (your green wire). Pin #4 is - (your white wire). Now the orange pins, pins 1 and 3 these are for the HDD led. The bottom pin #1 is the HDD + pin (your red wire). Pin #3 is the HDD - (your white wire). Now the pink pins, 6 and 8 these are for the power switch. Pin #6 is the + pin (your orange wire). Pin #8 is the - pin (your white wire). Now the blue pins, 5 and 7 these are for the reset switch. Pin #5 is the - (your white wire). Pin #7 is the + (your blue wire)."""
May 18, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Cmos clock will not set !
Is the cmos clear jumper in the wrong position? if it is it will drain the battery and mess up the clock, You may have to flash the eeprom with a newer version BIOS obtainable from the manufacturer, check their website on this to see if it is a known issue ( I have seen this on multiple other manufacturers main boards). If this isnt it it is possible you have a bad clock chip
Dec 31, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Motherboard diagram
The instructions are straight forward on page 13+ in the manual below
heres the driver|bios|manual link
http://www.pcchips.com.tw/PCCWebSite/Downloads/
ProductsDetail_Download.aspx?detailid=341&DetailName
=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=2
the direct link to the manual
http://64.124.27.139/DLfile/manual/848Av50.pdf
Feb 23, 2008 | PC Chips M848ALU Motherboard
Jack call-outs and drivers
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=24&LanID=0&DetailID=251
hope that fixes it for you :)
Jan 06, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Soltek SL-PT880E-RL Motherboard Logo
161 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
David
David
Paul Bade
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
