Question about RCA D52W19 52" Rear Projection Television
Replaced parts--here's where we/re at
Replaced flyback and two capacitors. Tv powers on but only the blue lamp fires, nothing from red or green. Can't see where anythis is disconnected. Had a local tv repairman recomend that the HV Splitter could be bad, upon inspection there are no cracks and there is power to the blue lamp. Any suggestions?
  • RCA Master
  • 5,138 Answers
Check all tubes Red ,Green look for crack or broke some even leak fluid out on board.
Posted on Sep 24, 2008
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
No picture
I disagree with given info, this tv has no horizontal output transistor because it is dlp tv.
3 red light blink means lamp cover is not placed back properly after lamp replacement/ lamp checking. Make sure lamp cover is fixed back in its place securely and tight.
Jul 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba 57H81, power to transformer and flyback.
IF YOU REPLACED THE SAME PICO FUSE, YOU PROBABLY HAVE A BAD CONVERGENCE IC AGAIN . DID YOY SNUG UP THE IC TO THE HEAT SINK AND USE THERMAL HEAT COMPOUND ON THE NEW IC'S? ALSO CHECK SOLDER CONNECTIONS TO C810 AND C809 THE FUSE BY THE CAPACITORS MAY BE OPEN.
Jan 22, 2009 | Toshiba 57H81 57" Rear Projection...
Sound but no picture on RCA R52WH74TV.
You do not have Lamp in this set it is Projection has 3 Tube Red,Green,Blue. On power/deflection board CK capacitor cp150 2200uf 16v look to see if capacitor is puffed up on top if so replace it and 2 other caps in same circuit 220uf 35v they are green with gold writing on them also CK second ribbon connector make sure it is pluged in good.
Dec 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20 TV will not turn on, already replaced flyback & cp150(was blown)
Hello weewilliemom,
Have you tried to see if CP120, CP140, and CP150 are good? These capacitors usually are the cause of the problem you are experiencing. I have a copy of the schematic is you need it.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi TV no picture no sound
Most common fix is shorted cap C702 ? near flyback transformer
and open E994 pico fuse in power supply. Capacitor is sometimes partially covered by glob of glue from factory....
Let me know right away,please......................T.
Dec 03, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
