I think I just answered this If you did not recive my response please email me
Thaks for getting back to me with your problem. remove the filter and check the coil and see that its clean. If not you can vacume it off. If it is then you will have to either remove the unit and take a look at the outside coils and check them , though i doubt there is any problem . If the coils are clean and the fins are not bent and the fan is working properly ( all of which will require you to plug it in -inside the apartment) I would bet your unit is about to give up the ghost or has leaked freon some how. You can tell if you have leak by looking for oil any where on the unit . it won't just be a spot but quite a bit of oil. either way I think this will be more then we can solve here online as you will need equipment to check it futher . let me know though what you find if you pull the unit out to look at theoutside coils. Jon
try shutting it down ofr a while.hour or so. check the filter and be certain it is clean. let me know question is the air coming out cold or at least cool
I shut it off all night and yesterday we cleaned out the filter. It is on again but the air is only coming out cool not cold.
