Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice dispenser - model FRS26ZRGW8
When we press the dispenser to get ice cubes- it takes a while for the flapper to open and then several cubes come out all at once. What can be done to open this flapper faster?
  • Anonymous Oct 19, 2008
    I no longer can get ice or crushed. I'm ready to buy a new one
I had the same problem, then it quit dropping cubes entirely.
The problem seems to be a failing linear actuator.
I'm unable to locate a replacement part, hopefully someone can help us.
Linear Actuator info:
115 volt
Posted on Sep 01, 2008
How do I remove ice dispenser from samsung rfg297aars
here ya go.
Grab the black dispenser port with a strong hand and hold the door from opening with another, or your shoulder. Firmly pull the assembly away from the door. It will take a quick, firm pull to do the deed. The assembly is held in place by several plastic lock tabs. These will give way without breaking.
pushing the fridge back will be easier than pulling it around.
Best of luck and hope this helps you.
Jan 18, 2018 | Samsung Refrigerators
Why are my ice cubes dispensing faster than my crushed ice. I changed the auger assembly and crush ice is still slow coming out of dispenser.
Hello Theresa;
My name is Peter. I am a retired field service refrigeration technician.
I have gone on many a service call in regards to this issue. People like their crushed ice.
The auger was not the problem. It is the nature of the beast.
Regular ice cubes have more density (Heavy) and exit through the door dispenser with no problem.
With crushed ice, shaved chips they are lite. When you dispense crushed ice the ambient room temperature (warm air) creates condensate and bines the crushed ice together. Fragments of the crushed ice block the dispenser flapper from closing all the way. The flapper remains a little bit open and ices up.
The manufacturers recommend after you run crushed ice that you run cubes through your dispenser to clear the crushed ice fragments.
Well, that solution is from engineers sitting in a office.
The solution is, from a old experienced field technician is: Reach up and wipe the flapper with a dry cloth. Look up and make sure the flapper is completely closed.
If you need a tech call me at 414-306-1362. Glen Burnie, Maryland, USA
Dec 30, 2014 | Refrigerators
Whirlpool model # ed5vhexvq1 side by side maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Ice dispenser frigidaire
Hello Friend, thank you for allowing me to assist you!
From what you have described it sounds like the issue lies with the door switch, auger motor, or a faulty ice door flapper (the flapper that opens to allow ice to dispense). In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your Frigidaire refrigerator. Best! - Z
Sep 04, 2014 | Frigidaire Gallery Side By Side...
Why are the cubes not breaking apart when dumping from the tray?
It is over-filling and the cubes are fused together... If the fill is adjustable, lower it, but you may need a new water valve... Frigidaire Water Inlet Valve 242252702
Jul 31, 2014 | Frigidaire FFSC2323LS 22.6 Cu. Ft....
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
48 " viking ice maker tray frozen no ice
Try replacing
the icemaker unit. I used Supco model RIM943 and its working great. Found it online for $55 on line.
My Viking 48" ice maker has given me a little trouble too. The first ice maker assmble was replaced under warranty. It only came with a one year warranty so when it just went out again I thought I would take a look. Just like you I had no ice. It only take two screws to remove the ice making unit and a quick discount plug. I read up on the unit to trouble shoot it. My Ice maker had the ejection forks stuck in the down (in the ice cubes) postion indicating the unit was out of sync and needed to be completly replaced.
On another note:
I also had a proble with the flapper ice cube door on the outside ice dispenser. Ice cubes would get stuck in the door and would not drop into the cups. This was a lot tougher to fix, but I like figuring things out. Turns out I had some ice that got stuck in the flapper and some how it melted and froze back up to lock the flapper. When the motor came on it sheard a shear pin in a coupling just off the drive motor. I made a home made shear pin and put it back together and all work great now. It was a bit of work to take it all apart and to tell that the motor was good and the relay was working right.
Jul 27, 2009 | Viking VCSB423 Side by Side Refrigerator
Only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice dispensor
Make sure that the "flapper-door" closes about 3 seconds after the ice dispenser button is released. Mine had a habit of catching and staying OPEN. This allows warm air to enter the dispenser / freezer compartment causing your problem.
If it is stuck you have to take the dispenser apart to loosen / lubricate the flapper door cam to allow for free movement.
This is the worst ICE system I've ever seen for a variety of reasons.
Jun 06, 2009 | LG LSC26905TT Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
134 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
