Question about RCA HD52W59 HDTV Projection Television
The tv will not power on - RCA HD52W59 HDTV Projection Television
  • 4 more comments
  • Anonymous Sep 08, 2008
    TV willnot power on
  • chosenones Sep 12, 2008
    green light comes on for 3sec. than cuts off . wait 1min. and hit the power button and still wont work.
  • julied565 Oct 21, 2008
    My television will not come on. When I hit the power button it tries to come on 3 times and then goes off. Can you help me with this problem? The cable guy told me that RCA televisions have had recalls. This sounds like this could be my situation as the other person describes the same thing I do about it trying to come on 3 times.
  • hockeyfam Oct 29, 2008
    My TV just went black the other day. No power is getting to the unit at all. No breaker or outlet problem in our house, just no power to the TV
  • Anonymous Nov 07, 2008
    I tried to turn my Daenyx lCD flat screen on after I cleaned my house and it doe not work.
  • Anonymous Feb 01, 2009
    yes ,led light would flick several times and tv will not power up
You have three small red rectangle shape object.these are fuses. looking from the back of the set right next to the flyback on the right.one must be open, just put another fuse in or check all three.
Posted on Sep 12, 2008
My TV is doing the exact same thing
Posted on Sep 07, 2008
Yes it does blink 3 times and never comes on
Posted on Sep 06, 2008
  • RCA Master
  • 8,617 Answers
Does the led blink a certain amount of times before going out when you press the power button? Please respond to this same post when replying and I will assist you with the problem.
No power
Posted on Sep 27, 2008
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
Power led light blinking
Tries tv unplug,replug it back like about an hour later,now the tv should be resetting itself back to the factory setting.The tv now should be working agin.If tv still have the same problems,mean the tv power supply board it is the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
May 14, 2011 | Sony KDF-E50A11E TV
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
Power went out and when it come back on the tv took a long time to start and the screen was verticle stripes (multi-color)
Check if the issue is with the TV by connecting any other device.
If the issue is with the TV, then try resetting the TV to the factory settings by performing the below steps:
To reset the TV, turn ON the TV, then while holding down the UP ARROW button on the Remote Control, press the Power button on the TV front panel.
The TV will turn OFF and then turn ON again. Then release the UP ARROW button to complete the reset procedure.
If the issue still persists, try Power resetting the TV.
To Reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV.
If the issue still persists, service is required for the TV.
Jul 12, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
Power off presents magic focus screen, tv must be unplugged.
you will have to determine if tv fault or cable fault, shut down cable box and unplug it`s power cable. Once all power is removed from cable co. equipment retry your tv controls, if tv turns on correctly problem with cable co, if not tv has corrupted data (try unplugging tv for 1 minute and then retry) ifstill bad tv has bad control board or logic problem, either one will require tv tech to fix, hope this helps, video-tek
Jun 01, 2009 | Hitachi 57F500 57" Rear Projection...
Timer light blinks on and off and tv wont turn on
Resetting the TV
NOTE:
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
160 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
