Question about HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 won't initialise
When I turn the power the printer wakes up ( buttons flash, display comes up ) but then dies immediately and is out for the count. Any ideas ?.
  • 234 Answers
Unplug the power cord from the All-In-One and also from the wall outlet,
Leave the cable unplugged for atleast 1Min.
Connect the cable directly to wall outlet without the surg protector and before connecting it to the All-In-One press and hold the # and no 6 Button and plug the cord to the unit without releasing the keys, it should come up with the message as Semifull Reset
If the display goes off or printer turns off then release the keys and turn the power on.
Good Luck.
Posted on Aug 31, 2008
SCANNER FAILURE
The issue is with hardware of the printer.
Scan feature is most expensive and sensitive part of the printer.
I suggest you to contact HP support. If the printer is under warranty you may get a replacement printer or else they may give you a better option.
If not on warranty you may try this workaround:
  1. With unit off, press the 'Cancel' (pink button) and 'Color' (green button).
  2. This will start the printer in a diagnostic mode. Press '1' to run the diagnostics.
  3. Press 'Enter' or other keys as directed by the display prompts. When you don't know what to press, the 'Enter' key usually works. Some of the keys called for (for example 'Plus' and 'Minus') are not on every psc 2210 keyboard. They are mapped to one of the "directional" keys just above the numeric keypad area next to the 'Enter' key. Keep trying keys till one works.
  4. After all the diagnostics, the display will either go blank or display 'Initializing...' . Wait 10-20 seconds to make sure it isn't doing anything else then press the 'On' key.
The printer should start without the scanner error and the grinding/chattering noise.
Leave the printer on because the next power cycle brings the chattering noise back.
But, when it does, the procedure above seems to fix it every time.
PSC 2210 scanner failure HP Enterprise Business Community
Feb 18, 2014 | HP PSC 2210 All-In-One InkJet Printer
Printer buttons all flash green when I turn it on
You can usually download a pdf manual from HP support for free.
Here is a link to on on Fixya
http://www.fixya.com/support/p378621-hp_psc_2210_all_in_one_inkjet_printer/manual-3472
The manual should have the error code near the end of it.
You may want to go to HP support to find the exact error code shown by the lights and how to resolve it. Usually given that you just changed cartridges I would say one or more isn't seated correctly. Take them back out and reseat them and see if that fixes it.
Without the exact code being displayed I can't give you the exact proper answer/fix.
Aug 21, 2009 | HP PSC 2210 All-In-One InkJet Printer
Self test flashes for a few seconds comes when power is connected and then power is lost
check us power cable that is ok? and also check ur usb cable which is connected with the pc. if power cable is ok then i think its ur hp power button fault. then repair ur power button. then it become ok
Aug 03, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 all-in-one printer continually says to press enter to realign cartridges. After realigning I get this same message again.
The above solution is a detailed review of how to solve all of the cartridge related problems.... The simple answer to "BYPASS THE ALLIGNMENT FUNCTION is to press and hold the setup button then press the options button. The printer will immediately be ready to accept a print or coppy order. Happy days to ya..
Aug 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer fault
check the power cable connectivity ...
unplug the power cable
press and hold # and 6
connect the power cable back in and keep these buttons on hold till the screen goes off or says semiful reset, if it turns off press the power button to turn it on and follow the screen it ll prompt u to press 11 for english and so on ...
Hope it works
BEST OF LUCK
May 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Put in a new cartridge
i don't have driver
i want to load driver printer hp psc2210
Apr 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Language help on the Printer Display
Njoy
Jan 22, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210
1.) Double check the power outlet that your printer is pluged into. Swap to another outlet. 2.) Double check the plug at the printer end, it may go in only one way. Still no power when you press the power button? It may be bad. Return it.
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Hp 2210
The bulb in your HP PSC remains on for a specified period so that the unit
is immediately ready to respond to your request. When the HP PSC has not
been used within that specified period, it turns the bulb off to preserve
power and displays Power Save On in the front-panel display. (You can exit
this mode by pressing any button on the front panel.)
Your unit is automatically set to enter power-save mode after 12 hours.
Follow these steps if you want the HP PSC to enter this mode earlier.
1 Press Setup.
2 Press 5, then press 6.
This selects Maintenance, and then selects Power Save Mode Time.
3 Press until the desired time appears, then press Enter.
http://h10032.www1.hp.com/ctg/Manual/c01176633.pdf
Nov 10, 2007 | HP PSC 2210 All-In-One InkJet Printer
Replacing HP 56 Black ink cartridge
Turn off the printer for bout 60 seconds, turn back on and when it tries to initialise hold the set-up and options keys - worked fine for me but I don't know why. Hope it works for you.
Nov 02, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
