Question about Filter Queen Majestic Canister Vacuum
Stopped working My filter queen just stopped working. The one off switch will not work. I tried several outlets and it will not turn on.
  • mtdjsteele Oct 26, 2008
    My vacuum was working fine yesterday.  I just went to vacuum and the canister does nothing.  I won't turn on or anything.  I used several outlets to make sure it wasn't the power and also emptied the canister in case it was that.  However, nothing. It is about 6 years old.  Do they have a life time expectancy?
  • CJ C
    CJ C May 11, 2010
    has the unit ever over heated? what type of unit do you have??? model number which can be found under the cap on the top
I had a simular probleme with my older model filter queen vac and it turned out to be worn brushes on the motor I simply ordered new ones installed them and then and all it costs was 15.00 usd to canada probably less in U.S. go to this site you'll find all you need there. www.lighthouseenterprises.us
Posted on Nov 30, 2008
There is no power to my Filter Queen power nozzle. I have cleaned the connection and there is still nothing.
There is an electrical connection at the canister end and again at the beater end. If the beater is not working it is mostly that this is where you problem is. You need to test first to see if there is power at the canister end and then at the beater end. If there is no power at the canister it could be the outlet or something internal. If there is no power at the beater end then that outlet, or the cord could be the problem. If you have power and that end then the problem is likely within the wiring in the beater or in the motor itself
Jan 20, 2015 | Filter Queen Majestic Canister Vacuum
My filter queen majestic quit working. I opened up the unit to see what was wrong and I did not immediately notice anything wrong. Upon furter examination I noticed one of the traces on the printed circuit...
I recommend replacing the card. Soldering involves the risk of further damaging the card, so it would be useless anyway. Why waste valuable time?
There is a possibility of the motor overheating, generally due to a blockage in the airflow system somewhere. Check all filters, hose, wands, and power nozzle for dirt and/or clogs.
Check wiring connections, including hose to wands to power nozzle. Check all switches.
It sounds like you know how to do this, but if you have any questions, repost.
Jan 03, 2011 | Filter Queen Majestic Canister Vacuum
I got a used filter queen majestic vacuum at a yard sale and want to fix it up and start with new filters where do i get the filters and how do i change them
Well you bought a really great vacuum cleaner. The Filter Queen's are extremely durable and very well made vacuums. They sell brand new for over $2500, so picking one up at a yard sale was a great find by you.
There are several different filters on this model that need to be replaced. Here's a link to a 6 month supply kit that we sell, which contains all the filters needed for a 6 month period:
Filter Queen MediPure Filters 6 month supply
The only other part that you should be replaced on a regular basis is the belt (only if the vacuum has a motorized power nozzle for cleaning carpets). The belt should be changed every 6 months or so. Even if it doesn't break, these belts will stretch out and not work as well as a new belt would. Here's a link to the belt that will fit your Filter Queen Majestic:
Filter Queen Power Nozzle Belt to Fit All Majestic models using a flat belt
Here's a link to the owner’s manual for a newer Majestic model. This is the only one that is available online. Even though it's a newer model, the maintenance and care will be exactly the same for your model.
Filter Queen Majestic Owner’s Manual
I really hope this was the information that you needed. If you have any follow up questions, please don't hesitate to ask them by using the comment box here on the Fixya repair page.
If this did help you, please be so kind and rate my repair helpful, or leave some feedback for me. This is greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
Jun 15, 2010 | Filter Queen Majestic Canister Vacuum
I have a Vacu Queen V3000 and it stopped working in the middle of a job. I verified that I have power at the outlet that it plugs into and then checked motor resistance from the plug and I got about 600...
As a quick test Plug in the vac again and turn on the switch, then try your power head. If the head works you have a motor problem, if the head doesn't you likely have a cord problem.
You seem to be saying it failed while running??? which generally indicates your switch is the suspect.
Check the motor for a worn or sticking carbon brush.
Motor is access by removing the chrome lid and 3 screws under the handle., then removing the paper cone and unscrewing the center screw a t he bottom of the plastic.cone cage...
Dec 12, 2009 | Filter Queen Majestic Canister Vacuum
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
Carbon brush type
Zarico the brushes will be very difficult to find on that particular unit. unfortunatly the only way to resolve this issue is to update the motor itself. i can help you find a cheep alternative. being as all filter queens are on the same design you can replace the motor itself or update the entire top motor portion. here are a few links to try and help you out with your problem. http://cgi.ebay.com/FILTER-QUEEN-MAJESTIC-LTD-ED-MOTOR-UNIT-ONLY-PERFECT_W0QQitemZ390011060044QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item390011060044&_trksid=p3286.c0.m14&_trkparms=72%3A570%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
http://cgi.ebay.com/FILTER-QUEEN-VACUUM-MOTOR_W0QQitemZ350131357431QQcmdZViewItemQQptZLH_DefaultDomain_2?hash=item350131357431&_trksid=p3286.c0.m14&_trkparms=72%3A570%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
http://www.totalvac.com/accessory/parts/L-115750C.html
http://www.totalvac.com/accessory/parts/FQ-3309C.html
Hopethis helps ya out bud
Nov 02, 2008 | Filter Queen Majestic Canister Vacuum
Just stopped working
mine has a reset on the power head. alittle red button the back. if it is that old and worn out i would buy a refurbished one on like think i saw one for around $350. just search filter queen and u will find them
Aug 20, 2008 | Filter Queen Majestic Canister Vacuum
Motor
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Vacuum Just Stopped
Could be a bad switch or a bad cord would be the first things to check.
Jan 04, 2008 | Filter Queen Majestic Canister Vacuum
Majestic filter queen not working
could be power switch or power cord, happens alot
Nov 13, 2007 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
309 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
