Question about Tomtom ONE GPS Receiver
Random loud BoING noise while navigating to any site.
The Tom Tom continually sounds a loud Boing sound for no apparent reason. We can't discover how to turn it off or what does it mean. Can you tell us?
2 Suggested Answers
riceski
  • 1851 Answers
SOURCE: my nuvi 205 touch screen is acting up
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Posted on May 08, 2010
whitesox
  • 64 Answers
SOURCE: Tom Tom Rider
speakers are very vulnerable on these units along with radar detectors. they get jostled around and broken or garbled. The unit needs service or you can live without voice as i had to for a while(just got new unit 2 weeks ago)
Posted on Jul 26, 2007
My car sounds like a bell "ka-boing"
from your description of the damage it sounds like a metal reinforcement got loose (it helps the flat pice of metal such as the hood or trunk lid keep its shape and not flex) though it would help a lot to know year make and model of your car. is the dent only on the impact side of the trunk or did it form a bump on the side that didnt have direct impact, have you tried to pull the dent out? - that also puts tension on the metal and will make a noise. basically if you want to get a better answer let me know about your car and what has been done to it after the damage.
Dec 05, 2013 | 1998 Volkswagen Jetta
My car sounds like a bell!
I would suggest checking to see if you bent the exhaust when it hit the pole. The 1992 camaro has very little room for the exhaust system to run over the rear axle to start with it would not take much to make it hit under the car
When backing up or pulling into a parking space I get a ''boing'' sound. This noise doesn't seem to happen when I'm actually driving and come to a stop. What could the sound be?
If the noise occurs as you move off in reverse it could be the exhaust system touching the body as the engine tilts forwards in reverse. Check exhaust hangers as well as exhaust alignment. Also check condition of engine mountings as well as front engine mounting buffer as this tends to perish and disintegrate.
Jun 01, 2010 | 1998 Audi A4
When I turn on my tv all it do is make a boing sound
The boing sound is caused by the relay cutting in to allow power to the boards. However if you have no sound or display then one of the boards or components has failed. This will not be a DIY as it will require the diaqnosis of the true fault, that is.. whether the fault is on the power board or elsewhere in the circuit. Your only reliable and cheapest option is to submit it for repair. Average cost of parts at a guess about $100 + labour so lets say a ball park figure of $300. If it comes out less then you are still a winner.
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Emerson EWF2004 20" TV
Home did not install automatically. what to do next? I CONNECTED MY TOMTOM TO MY COMPUTER BUT IT DID NOT INSTALL.WHAT NEXT?
Navigate to your tomtom and double click setup.exe or install.exe (sorry can't remember which it's called but you will have one or the other not both) to navigate to you tomtom.....
...1. Make sure you PC's sound is on (this is simple but helps)
...2. Plug your TomTom into your PC (you should here a "boing" noise from your PC
...3. (depends on your version of windows) XP, Click start -> My Computer -> Tomtom
Vista, Click "Windows Logo" (bottom right) -> Computer -> Tomtom
...4. Double click on Setup/Install.exe
...5. Follow on screen instructions
Nov 08, 2009 | Tomtom ONE GPS Receiver
Every time the tv is switched on or off there is a loud "boing" noise. Very annoying if anyone sleeping in room. Can this be turned off?
I want you to try this swap power supply of the TV with a new one see if there will noise still .
Good luck
Dude
Oct 27, 2009 | Samsung LA32A450 32 in. HD-Ready LCD TV
Tomtom ONE GPS Receiver Logo
113 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
